'68 C60 temp gauge
Hello! I've been creeping around the forums for years and finally made an account. I have a '68 C60 farm truck with a 366 in it. The temp gauge never worked when I got the truck, but if you touch the sending unit wire to ground it pegs hot, so I know the gauge works. Being a C60 I couldn't find a sending unit listed for it anywhere. Working with my local NAPA guy we found a sending unit out of a 68 2500 396 truck that looks identical, but after installing it today the gauge still never gets off cold. Does anybody know what the resistance cold/hot should be for this truck's sending unit? Anybody know of where to get the right one? Any other ideas?
This is the sending unit I have now: https://www.napaonline.com/en/p/ECHTS6469 ![]() ~EDIT the old sending unit says "AC-Made In U.S.A.-12 VOLT" but I don't see any part numbers on it. Thanks!
Lance '88 RCLB K1500 Scottsdale Original 305/5spd 325xxx miles.(Build Thread) '56 Studebaker C-Cab Pickup 259 V8/4spd (Build Thread) '80 Chevy Luv 4x4 (Build Thread) '68 Chevy C60 366/5+2 Dump Bed Last edited by Triplel40; 01-12-2018 at 06:22 PM. |
The Older Generation
Re: '68 C60 temp gauge
There are two different sending units, one for the idiot lights and one for the gauges. I bet you have the wrong one. I can't tell you what the ohm readings should be but I would bet it's the sender..... Nice looking truck! LockDoc
Dude with the dual thermostats and the huge radiator, it may never get warm! LOL!
But LockDoc is right. Some of those had an idiot light AND a gauge. One on each head.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#4 | |
Check the wire and make sure it is not damaged. Basically your temp gauge is an ohm meter, so anything affecting conductivity will make it read wrong. When I first got my 68 back together I was reading cold or barely registering. My wire had been cut and was twisted together and taped, when I fixed it with solder and heat shrink the problem was resolved. -Richard
I may have too many Chevys... Is that possible? ![]() 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
Definitely have the right sending unit between the two options I found. I stripped the insulation back off of the wire and it is pretty badly corroded inside. I'll run a new wire to the gauge tomorrow and let you know what happens!
Lance '88 RCLB K1500 Scottsdale Original 305/5spd 325xxx miles.(Build Thread) '56 Studebaker C-Cab Pickup 259 V8/4spd (Build Thread) '80 Chevy Luv 4x4 (Build Thread) '68 Chevy C60 366/5+2 Dump Bed |
| Bookmarks |
