Livin' it up.
![]() Join Date: Nov 2001
Replacing Sway bar Bushings
Hey all i'm about to go buy some nice poly bushings and i measured my front bar 1 1/16 and the rear was 1 1/8. Do those sizes sound about right for a 3/4ton cst with a bb? I know the front sounds about right but i've no clue on the rear.
Also i was wondering what's the best way of going about this whole thing. The rear doesnt even seem to be tight or anything. Should i get a couple of shorter link bars (name?) for the rear if that is the case? The rear bar has it's D bushings held on by a bolt on each side of the trailing arm (2 bolts per arm) Seems like that's not enuf but then again it also seems liek the whole assembly isnt too tight. Thanks all for the help, Greg ![]()
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
I bought my sway bars from Early Classics Enterprise, I found them to be VERY KNOLAGEBLE on the subject. They sell a front bar that is much bigger and I think might be helpful with a big block! I think they can also help with the rear. good luck, sorry i'm not more help
70 swb restored by myself and some help from this board!! I hope to drive it some day!! portland OR |
Correct 67-72 3/4 ton front bars are all 1-1/16th.
Your rear bar is aftermarket. Can't help there.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
Livin' it up.
Well thanks for the info guys, just wish there was a bit more out there on how to do it. Aww well i'll dive on in there and figure it out i guess, maybe call Early Classic too for some info....
The simplest and cheapest would probably be Summit. Just measure your bars then tell them how many of each you need. Should be 4 for the front and 2 for the back.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
They're simple to replace. Just unbolt the bushing clamps and replace them.
