Old 01-15-2018, 05:35 PM   #1
Rod Run
Rod Run's Avatar
E brake pedal and cable question
Does anyone have a picture of the e-brake assembly under the dash.
I'm not exactly sure where this black bracket locates along the cable. I thought it would be pretty self explanatory once I got under there, but I guess I'm just an idiot and can't figure it out without pics
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 01-15-2018, 07:31 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: E brake pedal and cable question
That clip held the cable straight on the braket so it couldn't bind up.
See the 2 holes on bottom that's where it mounted to hold the factory cable in place.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-15-2018, 07:37 PM   #3
Rod Run
Rod Run's Avatar
I could see where it located on the assembly, but I don't know where it locates along the cable.
thanks for the input though, I appreciate it
Old 01-15-2018, 07:53 PM   #4
Andy4639
Old member
Andy4639's Avatar
It can't go but one place. The tab goes in the smaller hole and the other is for the bolt.
Old 01-15-2018, 08:05 PM   #5
FirstOwner69
FirstOwner69's Avatar
Does this help?
FirstOwner69 is offline   Reply With Quote
Old 01-15-2018, 08:58 PM   #6
Rod Run
Rod Run's Avatar
Originally Posted by FirstOwner69 View Post
Does this will help?
YES!
Thank you so much. That is exactly what I needed I guess my clamp is crushed down to much, because it would have never fitted over the cable like that.
You rock. Thank you so much!!!!
Old 01-15-2018, 09:34 PM   #7
notsolo
notsolo's Avatar
Ditto, Thanks for the Great Photo. I need the same photo for reassembly. I would have put it on upside down and backwards 1st.
notsolo is offline   Reply With Quote
