Old 01-19-2018, 01:26 AM   #1
Mr_Rich
Mr_Rich's Avatar
Front brake calipers
I was watching an episode of Car Fix this week and Lou and Jared were upgrading the brakes on an '89 Chevy van with truck parts. They were installing dual piston front calipers that were direct replacements for the single piston stock calipers. Does anyone have any info on this upgrade? I didn't see any reference to the parts in the credits of the show.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 01-19-2018, 10:09 AM   #2
sntrym95
sntrym95's Avatar
Re: Front brake calipers
There were no dual piston stock calipers that I'm aware of, so it was probably aftermarket parts they were using. I'd check Jeg's or Summit for kits for your truck. A quick search yielded single and quad piston caliper options.
Mike
sntrym95 is offline   Reply With Quote
Old 01-19-2018, 04:49 PM   #3
Tom
driving is in my blood
Tom's Avatar
Calipers couldn't be stock, and these trucks need bigger rotors more then anything.
Old 01-20-2018, 06:27 AM   #4
fredscarryall
fredscarryall's Avatar
Not sure if you want to upgrade a van or 88 to 98 truck. Heres the truck option by Ssbc. Quick change talked about earlier.It has a new dual piston caliper. Not probably what you looking for. This is not for everyone kinda expensive at $750.( this kit uses your stock rotors and bolt to your factory caliper brackets).If your looking for affordable brake performance.You could just go with drilled slotted rotors and ceramic pad. I got mine as set on ebay for $150 and it gave me way better stopping power. Or another more expensive option by az properformance is 14” revelator at $995. Its a really nice kit. But you have to have heavy duty spindles.
fredscarryall is offline   Reply With Quote
Old 01-20-2018, 01:11 PM   #5
Mr_Rich
Mr_Rich's Avatar
My current setup on the front is stock calipers with Brembo disks and Performance Friction pads. I rehabbed my brakes last year although the photo is actually from five years ago. I thought the show was interesting because it featured what looks like an upgrade with aftermarket calipers better than stock. My truck already stops pretty good since I also have a Stillen rear disk kit on my back axle. (That kit is no longer avail. and the calipers are Aus. and obsolete.) Not sure what I'm going to do for brake pads on the rear...
1989 K1500 Chev. EC
Old 01-20-2018, 01:14 PM   #6
Mr_Rich
Mr_Rich's Avatar
This pic is five years old although my brakes were redone last year with the parts mentioned in the previous post.
1989 K1500 Chev. EC
Old 01-20-2018, 02:29 PM   #7
Tom
Tom's Avatar
The only oem thing with trucks is a light duty vs heavy duty caliper, the HD version have a larger diameter piston otherwise identical to the LD version.
