01-18-2018, 10:53 AM | #1 |
83 C10 axle identification
I just picked up a 1985 c10 SWB stepside near Memphis. Trailered it home to Mobile last weekend. Got home and had a vibration above 50mph. traced it down to the axle, took the cover off and found the issue. the PO welded the pin thru the spool piece, I had to cut it to remove the C Clips. it was a 10bolt.
i went to the local pull a part yesterday and got a 12 bolt rearend out of a 1983 C10. I was wondering if any of you could identify it as being an 83 truck axle? stamping on the housing is GM72 the passenger side axle tube has a stamping of KAA 234W72 thanks in advance |
01-18-2018, 11:39 AM | #2 |
Re: 83 C10 axle identification
Picture would help a lot
01-18-2018, 01:10 PM | #3 |
Here's a couple the KAA and the 234W72 are on the axle tube
01-18-2018, 08:45 PM | #4 |
Moderator
According to the 1979-1984 parts books;
KAA is an 8.875 (Truck 12bolt) axle with 3.07 gears and JB1-JB3 Brakes used in 1979.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-18-2018 at 08:51 PM. |
01-18-2018, 08:47 PM | #5 |
One more pic
Posted via Mobile Device |
01-18-2018, 08:53 PM | #6 |
I did confirm the 3.08 gears on the ring gear it’s stamped 14:43
Got it installed this evening, now I have to a different u joint for the driveshaft. Existing one for the 10 bolt will not fit this axle everything else bolted up in place. Posted via Mobile Device |
01-18-2018, 09:03 PM | #7 |
Moderator
3896839 is the raw Truck 12 bolt casting number. All that tells us is it's an 8.875 axle.
The stamped three digit letter codes are what tells us what it came from and how it was optioned.
And please let us know if and how your repairs were successful. |
01-18-2018, 10:19 PM | #8 | |
Happy to be here
01-21-2018, 09:17 AM | #9 |
Thx guys, I got it on the road yesterday. I did pick up a conversion U joint it was at advance auto parts. Moog #372.
I need to check my ring gear in my old axle I believe my truck is running less RPMs now at 60mph. I must have had lower gears in the 85's 10 bolt, again thx for the help |
01-21-2018, 12:46 PM | #10 |
Moderator
You can look up the original axle ratio in the parts books using the three letter 10 bolt axle code off the axle tube or just get the gear ratio off the gears.
If the old axle isn't the same ratio as the new one you'll need to swap the speedo gear(s). If you're lucky you'll only need to swap the driven gear. If you need to remove the driven gear you'll have to pull the tail housing. Get new seals and maybe even the driven gear housing if it's the least bit loose. I'd be sorely tempted to replace the output bushing in the tailshaft housing as long as it's off. The speedometer gear usage charts are in the parts books. You can download the 85-91 parts books and look em up. They're in my manuals post. Type "1985 SPEEDO GEAR USAGE CHART" in the search box and it should take you to the first page of the charts. If you leave out the year you'll get several hits before you eventually get to the charts. To read the speedo gear chart You'll need your tire size, RPO for the transmission you're running and the already known new axle ratio... 3.08... Not sure why GM lists 3.07 some places and 3.08 others. Meh close enough.
