Old 12-16-2017, 01:51 PM   #451
factorystock
factorystock's Avatar
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Originally Posted by oem4me View Post
Black. Pic is of an original paint truck in white.
This is why clean original trucks are so special, you can learn how the factory did it!
factorystock is offline   Reply With Quote
Old 12-16-2017, 11:29 PM   #452
Submariner616
Active Member
Sure is great having their owners on this site, too!! Terrific help to those of us doing a stock restoration.
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 01-06-2018, 11:30 AM   #453
f66
f66's Avatar
Engine Casting Number, Casting Date and Assembly Date Question. Has anyone done research on known original trucks to figure out relationship of engine block casting date, engine assembly date, and vehicle final assembly? I have a 1966 Custom Camper built in Fremont, mid-June 1966. Am building a new engine. 327, with 3858174 block, the casting date is L-3-5 which equals December 3, 1965. The Flint assembly date = 1209 YH = December 9, 1965.
Is this block to early for my June built truck?
Thanks, Frank
f66 is offline   Reply With Quote
Old 01-07-2018, 05:28 PM   #454
VictoriaHardware
VictoriaHardware's Avatar
1-2 months is more typical, but that's not too early.
VictoriaHardware is offline   Reply With Quote
Old 01-07-2018, 10:26 PM   #455
yelmer
i also have a June built custom camper 327 cast date is June 13 truck was built June 20th The block stamp is June 15th
yelmer is offline   Reply With Quote
Old 01-07-2018, 11:20 PM   #456
f66
f66's Avatar
Thanks for the replies. Yelmer, your sequence is very helpful. Consistent with other vehicles I have researched. Shows how tight all of the assembly dates are.
Old 01-08-2018, 02:29 PM   #457
f66
f66's Avatar
Yelmer, my truck was built 14 June 1966.
Old 01-08-2018, 08:58 PM   #458
yelmer
Fremont truck? vin 177???
Old 01-09-2018, 02:11 PM   #459
f66
f66's Avatar
Yelmer, Fremont truck, 176396
Old 01-21-2018, 03:11 PM   #460
jbgroby
jbgroby's Avatar
I was sandblasting 2 OEM hood hinge assemblies and noticed a factory name stamp. "Hancock" embossed over a large 'H'. Are these factory OEM? If so we found another piece of the puzzle......
jbgroby is offline   Reply With Quote
Old 01-21-2018, 03:22 PM   #461
Llay R. Rac
Llay R. Rac's Avatar
Last week I replaced my original hood hinges with NOS hinges, both the originals and NOS had the Hancock emblem.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 01-21-2018, 05:03 PM   #462
jbgroby
jbgroby's Avatar
Perfect!
Old 01-27-2018, 12:22 PM   #463
f66
f66's Avatar
Here is the tag from my 1966 C20. How is this de-coded?
Thanks Frank
Old 01-28-2018, 02:53 PM   #464
yelmer
May 25 1966
Old 01-28-2018, 05:10 PM   #465
f66
f66's Avatar
Yelmer, thanks. Is there a reference for this. I get May. How is the day figured? I was thinking May 09 1966. Again thanks for checking Frank
Old 01-28-2018, 10:24 PM   #466
yelmer
well is it kind of strange . The year 1965 the 1966 trucks were made to determine the date of the tranny is from Jan 1 1965 to May 25th 1966 is 509 days i hope this makes sense take care
Old 01-28-2018, 10:49 PM   #467
f66
f66's Avatar
Yelmer, thanks. learn everyday. The date and timing works with my June built truck. What is the date of your transmission?
Old 01-28-2018, 11:11 PM   #468
yelmer
i checked mine it is also 509 7377
Old 01-28-2018, 11:15 PM   #469
f66
f66's Avatar
That’s neat. Thanks for sharing
Old 01-28-2018, 11:20 PM   #470
f66
f66's Avatar
Old 01-29-2018, 01:45 AM   #471
aotte1
Just FYI, another 66' Custom Camper turbo 400 trans built tag.
aotte1 is offline   Reply With Quote
Old 01-29-2018, 03:01 PM   #472
yelmer
Les looks to be Nov 20 which is a Saturday they might of had a shift is that 324 or 224 I did it for 324
Old 02-12-2018, 04:19 PM   #473
f66
f66's Avatar
Need help with parts numbers and ID. Attached are pictures of my 1966 C20 Bendix power booster and master cylinder. My understanding is these trucks could come with either Bendix or Delco Moraine boosters and M/C.
Questions:
1. The M/C has part number 618082 cast in the bottom and has a screw on cap. Is this potentially an original or replacement original?
2. What are the Bendix part numbers for the Master cylinder, and part number for the booster?
3. What are the Delco Moraine part numbers for the Master cylinder, and part number for the booster?
Thanks for the help, Frank
Old 02-12-2018, 08:14 PM   #474
yelmer
the parts book calls for moraine unit #5465489 1.0" bore with booster . booster 3834112 bendix (2501747}
Old 02-12-2018, 08:34 PM   #475
f66
f66's Avatar
Yelmer, thanks is my master cylinder the right part number? Also where is the part number on the booster? And last, are the boosters date coded?
