Old 01-24-2018, 07:53 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Side trim mounting holes
Only problem with the assembly manual is it doesn't provide a starting point, otherwise know as initial reference points. For example, the top image (post 3) reads 30" & 10". 30" & 10" from where?
I'm definitely subscribed, because I'm adding uppers and lowers. This subject has come up many times over the years. Ideally, someone might provide the vertical and horizontal measures for the outer holes for one side of the truck (tops & bottoms) from definitive edges. For example:
The rear edge of the door to the center of the first hole is:
The bottom rear edge of the door to the center of the first hole is:
The front edge of the door to the center of the first hole is:
The bottom front edge of the door to the center of the first hole is:
Yeah, that's just one of 10 pieces, and images would go a long way. Takes some doing. Makes me want to tear off the moldings on my driver......
If ever someone could do this, then we'd all know the exact locations.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
