LS swap
Does it increase or decrease the value of a 1970 model c10 to use new engine fuel injection ,ect over carbeurator.
Re: LS swap
Unless truck is in very good shape , LS is worth more than truck .
Stan 67 swb BLU MULE posted via flip-fone |
Re: LS swap
Depends on the truck ---- I disagree with harpo231 though --- An LS engine can be a fairly low cost procedure, --- people have done the swaps for less than $2500
A $2500 67-72 nowadays is basically a parts truck unless you get pretty lucky stumbling onto something
Are you retired too? Nonsense! I'm in my prime |
Re: LS swap
I disagree with Streetstar,, I wasn't talkin about a junky ls , meant one worth the time.
Re: LS swap
I guess I should have said this is a pretty solid low optioned 350 auto fleet side truck. No body work done and very little rust. I have the option of using a motor setup lt1 from a 94 roadmaster with 67,ooo original miles and a 97 ls motor with 86,000 miles. I have both complete vehicles for the swap. Just trying to find out if it is worth the trouble.
Re: LS swap
If ya already have the motor ,,,heck yeah
Re: LS swap
Right now, the going rate for a good junkuard generation 3 5.3L is about 500 bucks...and that's going to get you a 290hp/330 ftlb of torque engine that is reliable for 200,000 miles, and will get good fuel economy. I think that's worth the time and money
2009 GMC Sierra 1500 2006 Buick Lacrosse 1987 Chevrolet V10 1972 Chevrolet c20 350/350 1967 Chevrolet Biscayne ls3 swapped |
Re: LS swap
IMO, the later model motor swap is a great value when you score and use all of the late model features. Specifically the fuel injection but more importantly the integrated computer controlled transmission.
In terms of value, a hot rod is hard to price. It's worth what someone is willing to pay at that time. It may be a guy who hates FI and is willing to pay more. Or it could be the guy who hates carbs and that's what he wants. If you are building the truck for any other reason than that is what YOU want then you are likely to be let down in many ways.
#9 | ||
Re: LS swap
The other side of the coin though, if you are building it for yourself, and you do the work yourself, then you will know how to fix any problem that may arise. LS swaps are great for economy and drivability. No pumping the gas to get them to start, and temperature and altitude doesn't affect them so they are always the same, pretty much what everybody is used to these days. There are pros and cons to both. I prefer swaps, but have a buddy who prefers bone stock, so there's really no one answer, it's your truck, do what you want.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
