01-24-2018, 09:45 AM | #1 |
kinda stumped... ideas??
I got my frame powder coated and left a rivet and bracket for the lower control arms on the frame......... now when i went to install the lower control arms, i noticed that somebody put the locating rivet in from the bottom instead of the top....... so the oval head wont fit into the lower control arm locating holes..... how do i go about extracting the rivet without damaging the powder coating so i can reinstall it from the top?
RIZ 81 C10 short box 82 K5 Blazer |
01-24-2018, 01:10 PM | #2 |
Re: kinda stumped... ideas??
That is why I prefer paint to powder coat. Powder coat can not be touched up like paint can. The simple answer is you can not remove the rivet without damaging the powder coat.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
01-24-2018, 01:36 PM | #3 | |
67-72 parts collector,…
I guess a picture would help,...
01-24-2018, 07:18 PM | #4 | |
I did several areas on my chassis & you'd be hard pressed to tell where repairs were done.
01-25-2018, 08:08 AM | #5 |
I left that lower control arm bracket on when i sent it off not knowing the rivet was in upside down. It was like that.
01-25-2018, 08:13 AM | #6 |
yup. impossible...... nothings impossible........... I guess you just give up or don't try.
