Old 01-23-2018, 11:47 PM   #1
7echo
lowering
I took the rear shackles off to drop the rear so the truck was closer to level.
If I wanted to drop the truck a little more is it possible without replacing spindles or any other major work? Just a little lower, maybe an inch, or 2" max.
1993 Silverado, 305, auto, short bed
7echo is offline   Reply With Quote
Old 01-24-2018, 03:17 AM   #2
EVRLET
EVRLET's Avatar
Re: lowering
Your choice to lower the front is as follows:
Lowering springs - 2”
Dropped spindles - 2-2.5”
DJM tubular control arms - 2”
Remember these year trucks had kits that dropped them:
Front/Rear
2/4
4/6 - requires c-notch and under bed trim above pumpkin
5/7 - same
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 01-24-2018, 04:42 PM   #3
Tom
driving is in my blood
Tom's Avatar
Re: lowering
Lowering springs are availalbe in more then just 2", namely 1" and 3" drops as well. I never found any 2.5" drop spindles for this gen truck either.
OP- so you lowered the rear some, are you asking about rear only or the entire truck down 1-2" more now?
Old 01-24-2018, 04:53 PM   #4
7echo
Re: lowering
"OP- so you lowered the rear some, are you asking about rear only or the entire truck down 1-2" more now? "
Lower the entire truck another 1" or so. It is currently fairly close to level so I would want to drop it an equal amount front and rear.
Old 01-25-2018, 03:57 PM   #5
Tom
Tom's Avatar
Re: lowering
Rear you can do the leaf spring front mounts known as hangers, or get lowered leafs. Front I'd just get some new springs, they don't make 1" spindles.
