Cab dolly dimensions?
I'm getting ready to pull the cab off the frame and am wanting to make a dolly to mount it to and to roll it around on. I know some people have made them before, but was wondering if anyone has the dimensions of the cab mounts, so I can actually bolt the cab to my dolly? Open to any pointers on the construction of the dolly also. Thanks!
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Cab dolly dimensions?
What Year?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Sorry, it's a '66
made mine out of 2''x10's 42'' wide-471/2'' long(front to back) 3'' taller at back of cab sorry pick not that great hope it helps a bit....dan |
#5 | |
Ill be building one soon. Thanks!
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901 |
Never Ending Projects
Sorry I don't have any measurements but this is what I built for my '68 cab. It allows me to roll it around and to rotate it onto it's back, so I could strip the underside.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thanks for the ideas! I never thought about making it so you can roll it over on the backside...that's good thinking!
#8 | |
60-66 Nut
#10 | |
![]() Join Date: Jul 2017
What size pipe did you use to make that rig? I am going to try to make myself one of these. Did you have to support the back of the cab when you leaned it back? Thank you! |
#11 | |
Nope, no support for the back. It was firmly bolted to the dolly via the factory body mounting points. I could roll it on it's back without any issues. It worked great.
![]() Join Date: Mar 2004
I took a pallet, stacked (3) 4x4 boards on top of it, then screwed 2 harbor freight furniture dollies to the bottom side of it.
I am loving Chevy Mikes set up ![]()
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
