Old 01-26-2018, 04:33 PM   #1
gsharp
64 C10 Power Steering
I know know that I would have done more research before buying components if I had to do it over. That being said I have an 81 power steering box mounted to the 64 frame and an 84 454 with hydroboost power steering pump. What hoses do I need to tie the pump to the gearbox not installing the hydroboost breaks. Need a high pressure hose with two ends one with long 90 to clear the frame and the low pressure return. Motor is already in with the pump and reservoir.
gsharp is offline   Reply With Quote
Old 01-27-2018, 12:29 AM   #2
Captainfab
60-66 Nut
Re: 64 C10 Power Steering
If you are still running the long water pump, I would look at a hose for an '84 C20 with a 454 and see if that may work. That should have been available with a vacuum booster. If you had the hydroboost unit, you can always run that too. You would just need my hydroboost mounting plate to mount it to the booster bracket..
