Old 01-27-2018, 01:56 PM   #1
tim71
tim71's Avatar
WTB-Door/Window Handle Escutcheon in Parchment
I'm in need of 2 of the plastic trim rings that sit between the door/window handle and the door panel. They need to be parchment or off-white. LMC calls them Escutcheons, but their product is thicker in size and doesn't fit correctly. I was able to save 2 of my originals, but need 2 more. They're for a 1971 K1500. Any help would be greatly appreciated.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 01-28-2018, 09:55 PM   #2
tim71
tim71's Avatar
Re: WTB-Door/Window Handle Escutcheon in Parchment
ttt
Old 01-29-2018, 02:07 PM   #3
Lanman1972
Lanman1972's Avatar
I have some that I purchased from Brothers a couple years ago, new in the bag. I can check the thickness when I get home tonight. Do you have a pic or the measurement that works?
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 01-29-2018, 03:07 PM   #4
tim71
tim71's Avatar
The original and the LMC part are basically the same in overall height. However, as you can see from the picture, the original pushed into the door panel farther and the lip that remained between the handle and door panel is much thinner than the LMC part. I am curious if the Brothers part is the same as the LMC part. My guess is that it is, because they probably came from the same foreign supplier. Thanks for your help.
Old 01-29-2018, 03:46 PM   #5
Lanman1972
Lanman1972's Avatar
Mine look like the LMC part. I'll double check when I get home.
Old 01-29-2018, 07:17 PM   #6
Lanman1972
Lanman1972's Avatar
The parts I have look thick like LMC but they are soft and squeezable. Looks like they would push in. I don't have a door panel to try them on.
Old 01-29-2018, 09:15 PM   #7
tim71
tim71's Avatar
My LMC escutcheons are softer than the originals but I couldn't get them to fit to my satisfaction. Doesn't seem to be any members with any used originals laying around, so I think I'll try to modify the LMC pieces. They were inexpensive so it's worth a try. Again, thanks for your interest and help.
