Old 01-28-2018, 08:39 PM   #3
ZEKE68
ZEKE68's Avatar
Re: Mini starter for inline 6
Is your six block drilled for the diagonal bolts? My 250 six was drilled for both in line and diagonal starters. I always thought that the starters were the same for six and small block, and that what matters is the flywheel/flex plate diameter. the inline bolt starters fit the 153 tooth flywheels, and the diagonal bolt starters fit the 168 tooth flywheels. But that is just what I thought. May someone else will confirm it for you.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
inline 6, mini starter
