![]() Join Date: Apr 2017
eBay In Bed Spare Tire Mount
Has anyone tried one of these?
https://rover.ebay.com/rover/0/0/0?m...2F391808449171. Seems like it should work fine.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
Re: eBay In Bed Spare Tire Mount
Should work
Never tried it, but if you want to save 10 dollars, take a look at Amazon - there are a lot of ratings for this product also.
Prob want one for each side if you got a locker.
Old member
That wouldn't be that hard to make.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
[QUOTE=Andy4639;8172944]That wouldn't be that hard to make.
![]() True. I have everything I’d need to make it out of flat steel. Probably take a coupe hours to cut, drill, weld, wire wheel, and paint. Mine would be more stout. Hmmm. Posted via Mobile Device |
