#376 |
Low & Fast!
Re: "Elwood" the 77_remix
Ken, I guess I will have to start coming back on here just to see pics of the new build. Lol looks good sir..
#377 |
I'm just glad to be here!
Nice updates. Looking forward to LST.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#378 |
Happy to be here
![]() Join Date: Mar 2000
Thank you sirIt will be here way too soon. Travis I try to post updates on Instagram and Facebook. The forum is still the best location to share and discuss in depth.
#379 |
Looks good..............don't know I would be able to start cutting up super clean stock sheet metal........... no going back to "stock" if the air bag deal runs it's course as other fads have done in the hobby.
Keep up the good work!!! |
#380 | |
A lowered truck? Very doubtful.... They've been around way too long to be called a 'fad'. Even static dropped trucks can utilize the mods for a much more pleasant driving experience.
#381 | |
Happy to be here
Regarding the air suspension fad, I dont see it going away any time soon. As Scoti mentioned even if I replaced the air suspension with coil overs like I have on Scarlett, the fender liners would be the same. As much as I LOVE the exteriors appearence of a stock GM truck, I have no reservations about updating suspension and drivetrain.
#382 | |
Happy to be here
#383 |
looking good Ken..your build threads give me motivation to get Lucy going.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
#384 | |
Happy to be here
#385 |
Happy to be here
I'm still chasing down brake line fittings, so I put that on hold for now. Instead I made more progress on the Slosh Tubz install. The drivers side is done, so I tackled the passenger side. Its a bit of a wrestling match to get them in place with out a spotter, but it can be done.
The cut on this side is a bit smaller this time. I spent time dressing the edges with a flapper disc so I can clean up inside the fender once I'm done with the mock up. I will protect the cuts and inside the fender with undercoating when finished. I got the tub in place and drilled the two front holes. I used longer than stock bolts to hold them in place while working the perimeter holes. Mark the center hole and drill it out. Use a longer bolt again to align the liner. I have found if alternate front to back its easier and you get a more precise hole location.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-24-2018 at 11:43 AM. |
#386 | |
67cheby
![]() Join Date: Sep 2008
#387 |
Happy to be here
#388 |
Happy to be here
Last night I discovered two things. One is, I will never earn a living as a template maker. Two is I am a persistent SOB, and persistence pays off. Mike Losh needed a set of templates made for Mild Tubz filler panelz to fit the 73-80 fenders. He asked if I would help him out, and I jumped on the opportunity to return a favor.
What I discovered is these panels are multi-dimensional and its a task to get them right. Instead of a pretty pattern, I created a Frankenstein cut out thats patched together with multiple layers of paper and tape. Its pretty scary, but it is functional.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-25-2018 at 01:22 PM. |
#389 | |
67cheby
#390 |
Happy to be here
Gee thanks, but I knew that was coming. Hows that saying go? "Trim to fit, paint to match"
#391 |
Happy to be here
Round two of my pattern making went much better. I thought I might be able to use the drivers side and flip it over. No such luck, but it did give me a starting point. This time I made it in three sections and adjusted accordingly. It did require a couple of add ons, but its not the Frankenstein pattern like the other side.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-26-2018 at 01:20 PM. |
#392 |
67cheby
well i approve!!
#393 |
Happy to be here
Does that mean you signed off on them? My legal team says I may have a loophole.
#394 |
Happy to be here
Switching gears last night I worked on the exhaust again. It's the last thing that needs to be done under the rear of the truck.
I plan to put the bed on soon so I want this completed. It doesn't do justice to the Deeds Engineering hangers, but it will work for now.
#395 |
Happy to be here
Saturday I located the last two fitting I needed for the Wilwood proportioning valve. I bent the lines that were waiting for fittings and mocked them up.
With all the lines complete I pulled it apart one last time. Now I can clean and prep the area for paint
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-29-2018 at 11:03 AM. |
#396 |
Happy to be here
I prepped and painted the bracket I made along with the crossmember its mounted to. The brake lines were complete, so I pulled them out and painted those as well. The brake lines were a lesson in frustration, so I'm praying they dont leak.
#397 |
Happy to be here
I had a paint mishap that prevented me from painting the exhaust Friday night. A word of caution. Always verify you have a supply of cleaning solvent "before" you load your gun. I had a clog in my color gun and no way to clean it out. It didn't end well as I used my last drop of Brake Cleaner to clean up the mess.
With a fresh batch of supplies, I was able to get the exhaust sprayed with Cerekote on Saturday. The instructions say it doesnt require reduction, but I feel its a bit thick straight from the can. I reduced it with DT 885 and it flowed fantastic. I layed down several thin coats it went on super smooth.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-29-2018 at 12:39 PM. |
#398 |
![]() Join Date: Feb 2011
Nice!!!! It's really coming along!!!!
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#399 |
Happy to be here
It seems like I'm loosing ground rather than gaining, but thanks for the motivation.
#400 |
Happy to be here
Last night I made the final install of the exhaust system. I had difficulty location a collector gasket that was the right size. I also decided to use larger rivits to hold the system together. Initially I had used medium stainless rivets, but a head popped off one so I went much larger.
Once I get the LST and Goodguys behind me, I'll have to to have a pro built system. Till then, my parts and pieces system will get the job done. Thanks again to Kevin Deeds at Deeds Engineering for the beautiful hangers.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-30-2018 at 12:03 PM. |
