73 C10 with 4 Link Coilover with C6 Brakes
This is a 73 C10 with a Ford 9'' with a 4 link and adjustable coilovers from ridetech and for the braking I am running OEM C6 Z06 13.5''disc with 4 piston caliper brakes no E-brake. Bed was tubbd to fit some fat rubber Mickey Thompson HR1 20x16 tires are 31x18
Re: 73 C10 with 4 Link Coilover with C6 Brakes
Ridetech 4 link Stainless finish
C6 Z06 Corvette 13.5 rear disc brake
Progress pics of the install
Ridetehc adjustable coilovers
Happy to be here
![]() Join Date: Mar 2000
Sweet! Love the M/T meats.
tubbd bed original look just wider. Tucking those fat 31" tires
Spraying the 9
4 link final
chevy runs deep
Nice pics
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
Junior Member
wow.... that is sweet........ ! Send me your contact info!
Looks so bad ass man! What are you doing for the front brakes dude?
BMW & ASE Master Certified
Who did you get your rear brake brackets from? Any reason why your not running the parking brake?
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Very Nice! Love the stock looking rear wheel tubs.
#15 |
#16 |
I got the brakes on ebay. 2 reasons why I am not running the Ebrake 1 money that option is like $700 more and I like the clean look of the cab with less pedals hangin and brake wires across the bottom. This option is upgradeable so if I ever have the need I can alwys install it.
#17 |
Front brakes are also from a C6 14'' discs with 6 piston calipers, they are huge. I havnt started on the front. I will completly redo the front suspension
new drop spindles, tubular control arms top and bottoms and run coilovers. Will eliminate the stock spring and shock set up. heres a sample pic |
#18 |
Alot of hrs. went into the tubbin process. The method of monting these wide tubs is just like the original fully removable not welded on, I managed to preserve the same bolt pattern.
few pics |
#19 |
67cheby
![]() Join Date: Sep 2008
nice work
#20 |
Garage wrench
I love the look of the stainless 4 link and coilovers
![]() very nice work, very clean build. Any pics of the truck complete?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
#21 |
Thanks. This is going to be my shop truck and it is still under construction here is a pic of the current stage. I have a build thread goin heres a link
http://67-72chevytrucks.com/vboard/s...d.php?t=375801 |
#22 |
Kvn1011
nice bro!!
#23 |
Sweet
#24 |
Just curious, what does converting to coil overs do to your payload and towing capacity?
72 Chevy C-10 w/ 67 front clip 355 ci Vortec 79 Lincoln Versailles 9" rear end, 390 gears 700R4 tranny McGaughy's 2.5" Front Drop Fatbar 4-Link |
#25 |
Do you know the part # of the Coilover you installed in the rear 4 link.
Thank you |
