Old 01-29-2018, 12:13 AM   #1
57larry
What is this part called?
on the passenger side inside the cab of my 68 is a round hole on the upper body, like a coat rack clip. what is this part called and where can I find one? thanks, Larry
57larry is offline   Reply With Quote
Old 01-29-2018, 12:34 AM   #2
Blue/72
Blue/72's Avatar
Re: What is this part called?
The hole was for shoulder seat belts, really rare option for these trucks. You can use the hole to instal new three point seat belts as well. These have a plastic plug over them. I have seen a few trucks with coat hooks mounted above the seat belt hole, and you can find them here, hope this helps!
https://www.classicindustries.com/pr...IaAlb8EALw_wcB
My dad always says that HEI distributers are pointless...
•1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money..
•1967 c10 with tach, dropped 3/5 on deep dish rally's
•1972 Cheyenne Super. Sold
Blue/72 is offline   Reply With Quote
Old 01-29-2018, 12:35 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Is there actually something there or just the hole?
LockDoc
Leon
Old 01-29-2018, 01:21 AM   #4
57larry
just the hole, looking for a plug
Old 01-29-2018, 08:48 AM   #5
yuccales
yuccales's Avatar
If you can't find a plug but want to fill those two holes, here's what I did. Napa has these LED marker lights. They press in pretty good. I wired them into the stock dome light wire. They are bright.
yuccales is offline   Reply With Quote
Old 01-29-2018, 10:08 AM   #6
Sounds like somebody knocked that out.
Old 01-29-2018, 10:53 AM   #7
LockDoc
LockDoc's Avatar
Try your local Ace Hardware if you have one. They should have them.
LockDoc
Leon
Old 01-29-2018, 03:01 PM   #8
LH Lead-Foot
My 67 C10 had a captured nut behind the plastic plug. I install 3-point seat belts from a mid 80's Blazer. Captured nuts are also under the seat on both sides of the hump. According to the FMVSS, seat belts for trucks where not required until July of 1971. They where an option prior to that. I also found an RPO code for "Large Rear Window" in 1967 as it became standard in 68.
LH Lead-Foot is offline   Reply With Quote
Old 01-29-2018, 11:56 PM   #9
Seat belts weren't mandated till '71 but were standard equipment through these years.
Old 01-31-2018, 02:08 PM   #10
57larry
as luck would have it, I was in LA for the roadster show, so I drove to Classic Industries. the part # is J1074, seat belt plug at $2.99 for 2. thanks for the help guys, Larry
