4l60e cooler line flow
What direction is everyone running there 4l60e lines to the radiatior. I was told bottom line on trans is discharge and goes to top of radiatior and top line on trans is return and goes to bottom of radiatior. Curious how everyone is doing theres
Re: 4l60e cooler line flow
It doesn't matter, but I put the hot side (being pumped out of transmission to cooler) on the higher port of the cooler, and the return side on the low side. The thinking here is that it doesn't need to be completely full for fluid to get back to the transmission if the cooler isn't completely full.
Really it shouldn't matter though, since having a empty cooler would mean that the ATF isn't being cooled, but I would rather the transmission has enough fluid to operate than to worry about it being low on fluid and the fluid being too hot.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Ok I figured if hot out is pumped to top of cooler it would return easier on bottom of cooler back to trans
GM Addicted
Lower line on trans to lower on radiator, upper from radiator to inlet on external cooler, then outlet to upper line on trans. If no external cooler than upper from radiator to upper on trans. Routing it opposite way could cause aeration in fluid. And we all know that’s not good for your transmission
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Monster transmission told me opposite of that lower line at trans is hot out and goes to upper on radiatior.
![]() Join Date: Jan 2016
The upper transmission fitting is the return from the cooler into the tranny.
The lower transmission fitting is the outlet from the tranny to the cooler. So- OUT the bottom, IN the top.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power Last edited by ga-stepside; 02-01-2018 at 10:59 AM. |
In the top of radiatior correct
It varies by transmission and it does matter, I'm told. TH400 is backwards from 200-4R, for example. 4L60E return is on the top. 4L80E is on the lower. And so on...
Any blanket statements about which way it goes without being specific to your model of transmission has about a 50/50 shot of being right. USUALLY though, and this is a gross generalization, I've noticed that they're typically laid out so that the lower port goes to the lower port on the radiator. That might not be 100% though!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Yeah it shows return port is top fitting on trans which means it goes to bottom of radiatior is how I take it
The top of the radiator is the hottest and the bottom the coolest.
In newer car tech, they use hot transmission oil from the converter to warm the radiator up faster to control exhaust emission sooner. In my truck the hot oil from the transmission goes into the top fitting on the radiator.
GM Addicted
Look at your crew cabs lines and route the same way. I’ve always routed the way I’ve stated with no issues.
Everyone says different things I did find this image and think I'll route them this way.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's another diagram.
It shows the hot from the trans to the bottom of the radiator,then to the bottom of the cooler and out the top of the cooler and back to the top of the trans. The hot fluid from the trans is going to the cooler port on the radiator and then out the top of the radiator through the external cooler back to the transmission.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#14 | |
Just confuse this topic further I have this quote from an automotive manual I have:
#15 |
Another thing I found when I installed the coolers in my cars and the truck.
Orientation as follows:
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
#16 |
I always found it was interesting that 200+ degree coolant is cooler than a transmission. Unless you are pulling, towing or hitting the metal under the pedal, it is a good idea to have a cooler. Since the top of the radiator get the engine hot coolant, make sense to run the red juice into the top of the radiator's internal plate cooler, to the bottom, where cooler coolant lives, out to cooler, then back to the transmission. For those of us who live on the North side of global warming (We called it weather when I was younger), I think I have seen a bi-metal valve that helps to keep the fluid from getting to cold...or is that even possible unless your cooler is the size of an old A/C condenser. Thoughts?
