Old 02-01-2018, 07:22 PM   #1
Anthony60
Hello and help with emergency brake cables
Hi to everyone. First time poster. Thank you to everyone for all your efforts to keep this site up and running. Thanks for being civil and kind to those of us with problems. I have always loved this era of trucks and have several projects waiting. Hopefully life will give me the time and energy to enjoy them. I am located in Southern Alberta and am presently working on a dusty 1968 C10 shortbox. I have it down to the frame and am presently reassembling it. I have installed a front cross member and a differential from a 1972 C10. I am at my wits end trying to get the emergency brake cable hooked up as it is too short by about 3 inches if I route the cable like a longbox. The cables are all new (Dorman) and seem to be the correct ones. They are however not exact replacements for the ones that came with the truck, except the intermediate cable which is the exact same length. My questions are (1) Does the cable run through the cross member in the holes as in Pic#1 or do they go in the holes closest to the main frame as in a long box? With the cable in the inner holes I am able to hook the cable up as shown (Pic#2) but without the guide hooks as they are now too short . (2) Are the guide hooks used (Pic#3) on a short box or are the only used on long box trucks? (3) Could I have messed up the installation inside the actual brake drum to be causing this problem? I have had the brakes apart several times, and all seems in order.
I have searched in the manuals that I have, but cannot find an answer. Hopefully someone will be able to help me. Thank-you very much. Tony
Anthony60 is offline   Reply With Quote
Old 02-01-2018, 08:55 PM   #2
notsolo
notsolo's Avatar
Re: Hello and help with emergency brake cables
I Don't know what the correct length cables were, I assume you have new rear cables also? Are they they close to what you had? ...Bruce's Build "Just a Pick up"...better than a shop manual. He comes up with a clever way to fix rear cables. Might work for you...Post 349...... http://67-72chevytrucks.com/vboard/s...318544&page=14
notsolo is offline   Reply With Quote
Old 02-01-2018, 09:10 PM   #3
Anthony60
Yes, all cables are brand new. The two rear and the front cable are slightly shorter than the originals. I have tried two different sets of rear cables Dorman C92416 and Dorman C92505 - no luck. The front cable is Dorman C92449. The intermediate cable is an exact match Dorman C92443. Thanks
Old 02-02-2018, 01:15 AM   #4
RedRider
RedRider's Avatar
Subscribed. I’d appreciate some clarity on the routing as well.
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 02-02-2018, 10:03 PM   #5
HO455
HO455's Avatar
The cables on my Burban are routed through the holes nearer the frame rail. But I find it hard to believe that make as much difference as you are seeing (wouldn't be the first or last I'm wrong) I believe there 3 kinds of rear cables, Coil spring, 2wd leaf, and 4wd leaf. You may have the wrong rear set. Or they were mispackaged. I can measure my rear set length tomorrow if that would help.
RIP Bob Parks.
Old 02-02-2018, 10:30 PM   #6
Anthony60
Thank-you for responding. I am pretty sure I have the right rear cables as they are almost, but not quite the same as the originals. In many of the parts books I have, there is only one choice for the rear cables for 2wd trucks. I have already tried two different part numbers from Dorman. I could be wrong though. On the long bed trucks I own, the cables are all routed like your Suburban. I was just wondering if the routing is different on a short bed truck. Thank you again. Tony
Old 02-02-2018, 10:36 PM   #7
ho70
ho70's Avatar
I went through 5 rear brake drums (same part number) to get 2 the same as my original ones
ho70 is offline   Reply With Quote
Old 02-02-2018, 10:51 PM   #8
stevenfromtexas
stevenfromtexas's Avatar
i know you'll get some replies from some way more qualified guys than me....
i took some pictures of mine when i read your post.....
i actually adjusted mine this evening....
not sure if its "correct" or not but it works and holds like's it is supped to..
i moved the "eye-let" to a different hole to shorten the cable....
i hope this helps
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline   Reply With Quote
Old 02-02-2018, 10:53 PM   #9
stevenfromtexas
sorry.....just saw you had a long box....
i'm a "short" box
sorry
Steven
Old 02-02-2018, 11:04 PM   #10
stevenfromtexas
another shot....
Steven
Old 02-02-2018, 11:05 PM   #11
Anthony60
No, it is a short box Steven. Is the cable routed through the inner or the outer hole in the x-member? See Pic#1. Thanks.
Old 02-02-2018, 11:07 PM   #12
stevenfromtexas
....errrrr sorry...forgot the pic..
Steven
Old 02-02-2018, 11:12 PM   #13
Anthony60
Thanks Steven. My worst fears have been confirmed. Now I have to figure out what the problem is. Tony
Old 02-02-2018, 11:19 PM   #14
stevenfromtexas
...standdby...
i am a total rookie...
there will be some very smart guys that chime in. i am learning as i go...
Steven
