Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-03-2018, 10:30 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
How To: Ruin a Perfectly Good 4wd
While searching the local classifieds for a 67 Mustang fastback or 69 Camaro project for my wife, I stumbled upon this 70 Blazer. Really, I wasn’t looking for another truck, I promise. I have enough going on with my 1970 pickup: How To: Ruin a Perfectly Good C10, but the price was right, so I grabbed it without a real plan of what I wanted to do with it.
The 45 minute drive home revealed what I already knew: it needs a little TLC, and it rides like crap. What to do?
Below is a picture from the classified ad and one from my first fill-up on the way home:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 02-03-2018, 10:44 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How To: Ruin a Perfectly Good 4wd
I got it home with no issues, and promptly started tearing into it to see what I’m working with. It’s very solid underneath, with some minor rust issues peeking through a 10 year old, pretty well done repaint which was done in a F*rd color, medium wedgewood metallic blue. The real rust is in the upper windshield frame, as it had been sitting outside for a while. Overall, a pretty solid running/driving truck that just needs some lovin’ to get it right
-Chris
Old 02-03-2018, 10:56 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
I kept thinking about what I wanted to do with this old thing and remembered I had seen a new product on the market from Polite’s Deadend Garage out of Biloxi, MS. Pretty slick pieces that take care of upper spring mounting, c-notch, crossmember, panhard, and shock mounting.
(pictures borrowed from azproperformance.com)
-Chris
Old 02-03-2018, 11:03 AM   #4
CG
BlahBlahBlah
These are excellent pictures! They really show how their set up works, thanks!
Looking forward to see the shots of the front suspension 4x4 to 2 wheel.
EDIT: Just saw those were borrowed pics ... I totally missed those when I was trying to get better shots of how their stuff worked.
Old 02-03-2018, 11:09 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
While I was pondering the conversion, I decided to put together this dirty photo-hack of what it might look like as a 2-wheeler. I was instantly sold. This thread will now serve as a 4wd to 2wd Blazer conversion walk-through, using stock or stock-like parts. There are a few conversions here on the board, including my own previous endeavors, that leave many questions unanswered. I hope to remedy that as we proceed here.
The order has been placed with DEG, so look for updates as the sparks begin to fly
-Chris
Old 02-03-2018, 11:12 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Check out K5 swamp thing on instagram for some pics of a rolling chassis using these parts: http://www.imgrum.org/user/k_5wampthing/4217446393
-Chris
Old 02-03-2018, 11:34 AM   #7
nlped
nlped's Avatar
I’m in for this one too... but don’t give up on the truck!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-03-2018, 11:45 AM   #8
lks dcvn
lks dcvn's Avatar
Ok - in for this one. I have a 71 4wd blazer running/driving project in the garage right now that I may go this route on... haven't decided what I want to do with it yet. This thread may change that though. You going to keep it 6 lug or swap it all to 5 lug as part of the process?
lks dcvn is offline   Reply With Quote
Old 02-03-2018, 12:12 PM   #9
smbrouss70
smbrouss70's Avatar
I'm watching!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-03-2018, 12:22 PM   #10
rwade
rwade's Avatar
What’s the cost on the rear notch kit? I’ve got a project in mind these would work nicely on
Wade
rwade is offline   Reply With Quote
Old 02-03-2018, 12:36 PM   #11
babyblueoval
babyblueoval's Avatar
Subscribed!
Maybe this will give me motivation to finish my 4x4 to 2x4 Porterbuilt C4 swap.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 02-03-2018, 12:54 PM   #12
darkhorse970
darkhorse970's Avatar
I’m in!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-03-2018, 01:09 PM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
Never! It’s part of the family
Plan is for 5 lug, so I can do the torq thrusts. Any 12-bolt or 10-bolt axle from 71-87 will slide right in and are readily available cheap. Even new replacement axles are relatively inexpensive. I have pondered using the 6-lug conversion discs and 15” wheel vintiques steelies with dog dishes, but the 20” TTs just look so good...
Originally Posted by smbrouss70 View Post
I'm watching!
This is at least partially your fault, thanks for tagging along
Wade
azproperformance.com has it for $645 shipped. I went direct through DEG and added a second crossmember for $100, which will locate above/near the spring perches to minimize framerail flex. Also got a set of their front shock relocators for $80.
Jason at DEG was great to talk to, answered all of my questions and then some, sent me a bunch of pics, and offered free shipping. Satisfied customer so far.
Originally Posted by babyblueoval View Post
Subscribed!
Yes, what’s taking so long? I’ve not finished three Blazers in the time you’ve not finished 1
Originally Posted by darkhorse970 View Post
I’m in!
Come on in, the water’s warm
-Chris
Old 02-03-2018, 01:32 PM   #14
PEDROSKI
PEDROSKI's Avatar
Looking forward to this conversion. Really like the rendering you made and it just leads me back to the Torq Thrust for my own k5. Classic styling.
72 2wd k5 blazer
86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE
Old 02-03-2018, 05:08 PM   #15
I am here to see the carnage, I mean transformation
Old 02-03-2018, 06:00 PM   #16
CG
BlahBlahBlah
Thanks for the link. Im not an Instagram user so I don't see this kind of stuff. I have no idea what size tire and wheel that guy is using but I like the fact that he has some decent sidewall.
Ill keep watching your build here. You do great work
Old 02-03-2018, 06:11 PM   #17
rustytruck50
rustytruck50's Avatar
Cool!!! I've hopped on the train, too!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 02-03-2018, 06:17 PM   #18
smbrouss70
smbrouss70's Avatar
I know, right? I'm liking those TTII's... Hmmmm...
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 02-03-2018, 06:58 PM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
Couldn’t agree more. I see other styles I like, but nothing ever competes with the TTs. I even did a version of the chop with Ramblers, which I like a lot, but they just looked like a platinum, diamond-crusted grill. I immediately deleted it and set the above as the plan of action
Oh, there will be carnage
Thanks! His wheels are 17” Coys c-55 with 255/50 and 275/50. Proven tire combo that looks and fits right on these trucks. I’ve just gotten so used to the 20s that anything else looks wrong to me now...
Choo-choo, here we go!
But, you have some *****in’ wheels already. Don’t derail that train
-Chris
Old 02-03-2018, 07:41 PM   #20
jaros44sr
jaros44sr's Avatar
Should be an interesting swap. Although, you are not going this direction, I always wanted to see if I could do a swing arm suspension with coil overs on a 4x4. Maybe I'll get some ideas as you progress
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-03-2018, 08:33 PM   #21
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Subed... you rat!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-03-2018, 08:39 PM   #22
twp1
I'm In!!!
twp1 is offline   Reply With Quote
Old 02-03-2018, 10:21 PM   #23
gringoloco
A guy with a truck
gringoloco's Avatar
Porterbuilt has a bolt-in coilover conversion; not in my budget right now. I think you could also make the NoLimit or RideTech parts work. Either way, trailing arm crossmember and notch placement should be similar/same.
Originally Posted by C10_ustacould View Post
Subed... you rat!
I’ll take that as a compliment
Originally Posted by twp1 View Post
I'm In!!!
Woot! Here we go
-Chris
Old 02-03-2018, 10:32 PM   #24
sprint_9
sprint_9's Avatar
Awesome, Im excited to see this come together, I kind of want to do a blazer myself sometime.
sprint_9 is offline   Reply With Quote
Old 02-04-2018, 10:17 AM   #25
whitesilverado
Your going to be using very nice product. Mine coming out good.
whitesilverado is offline   Reply With Quote
