Dual master cylinder, DUAL DRUM manual brakes...
Swapping over this weekend, read the excellent FAQ write ups, especially by Chief Rocka in ‘09, but there must have been at least 5-6 “THIS is the way they are plumbed from the master cylinder”.....front port (closest to grill, farthest from firewall) to front brakes.....followed by the exact opposite description a few threads later. There were great pictures and diagrams of both....my brakes will be NON POWER brakes, just my foot, so maybe the one picture with the description but has a power booster is not right???
WHICH way is it.......?????? |
60-66 Nut
Re: Dual master cylinder, DUAL DRUM manual brakes...
If you use a '67-'70 truck master cylinder, the front port is front brakes and the rear is for the rear brakes.
Moderator
![]() Join Date: Dec 2012
Yep. I've posted the exact pic you've used on other threads. Front to front on these, even though others have done it wrong and tell you it's right. I have the exact setup you're doing. Drum/Drum/dual/manual. Stops great.
![]() Join Date: Nov 2015
Front to deont is what I did, too. Love having power brakes.
Does anyone know off hand what the bore size is on the 67-70 manual master?
Thanks, Cris |
