Old 02-04-2018, 09:11 PM   #1
Darreola562
Dual muffler or single??
Thinking or running spintech mufflers on my c10 but trying to see what would be better if I run duals or singles... any suggestions?
Darreola562 is offline   Reply With Quote
Old 02-04-2018, 09:29 PM   #2
kwmech
Re: Dual muffler or single??
Single 3'' magnaflow in my 69. 454 automatic. Personally do not like headers or duals on a street truck. Did it when I was a kid.... got over it
Old 02-04-2018, 09:45 PM   #3
HO455
HO455's Avatar
Can you post some more info on the truck and how you plan on using it. Then folks can make a more informed reply.
RIP Bob Parks.
Old 02-04-2018, 11:54 PM   #4
jessemthompson
I run 2 1/2” dual exhaust with headers, an H-pipe and spin tech mufflers. I absolutely love the way my truck sounds. Not too loud at idle, but at wot it has a mean bark and I don’t experience any drone in the cab.
jessemthompson is offline   Reply With Quote
Old 02-05-2018, 03:41 AM   #5
Darreola562
Truck is a basic 350 recently rebuilt nothing fancy automatic transmission 71 shortbed. It is your stock truck.
Old 02-05-2018, 03:42 AM   #6
Darreola562
Any difference between running 2 1/2 inch pipes versus 3”? Does it make a difference in the sound at al, performance, etc...?
Old 02-05-2018, 07:40 AM   #7
bbrriiaann1973
I have a 383 with headers and true dual exhaust and couldn't be happier. The louder the Better! Anything to piss off the neighborhood!
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-05-2018, 09:55 AM   #8
Alex V.
Alex V.'s Avatar
Dual 2" is adequate on a stock small block - 2 1/2" with any kind of performance muffler should be ample. I prefer duals on a V8 - both my trucks had it before I got them.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 02-05-2018, 01:08 PM   #9
demian5
demian5's Avatar
On a BBC the single gives you way more grunt.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-05-2018, 02:26 PM   #10
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
On my built 396, I am using Hooker headers, a Black Widow X pipe, Flow Master 44's, and 3" pipe all the way thru that end behind the rear axle pointing down to the ground at a 45deg angle under the bed.
Very nice sound. No groan inside of cab at any RPM or speed.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 02-05-2018, 06:40 PM   #11
arks
arks's Avatar
Mine has a 350 with stock manifolds. It's got really simple 2-1/2" duals exiting under the bed just ahead of the rear wheel wells. I like the sound.
They're just loud enough to help drown out the wind noise!
1970 C10 short stepside
350/700R4
arks is offline   Reply With Quote
Old 02-05-2018, 08:21 PM   #12
Mike C
Mike C's Avatar
When I had my '70 GMC with the 402 in it I was planning on a single 3" RV style muffler.
For my Jimmy I have dual 2 1/2" in Walker Hemi Turbo mufflers connected to Corvette cast iron manifolds. The Butt-o-Meter suggests it equals the power output of the Heddmans and 2 1/4" exhaust it replaced.
I'm planning on same exhaust setup for my 69 short step when I swap in the 427 but am running the very expensive Sanderson iron manifolds.
Engine Masters did a 2 1/2" versus 3" exhaust system and it's not worth it unless you are north of 600 whp. 2 1/2" was cheaper, easier to route, quieter and made equal power.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-05-2018, 10:08 PM   #13
Don Quixote
Don Quixote's Avatar
My 292 runs a dual 2-1/4" with Magnaflows and an H pipe. I can barely hear it idle but it's got one hell of a getting when I mat it. I do have a drone at 55mph but I don't have a floor mat either.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 02-05-2018, 11:56 PM   #14
Single factory exhaust is purely a matter of economics. Two cylinder heads/two exhaust manifolds means two pipes for me. I'm 62 and will never outgrow that . It's the first thing on my list, usually.
