Power steering install issues - help please
Hi all, we're now at the end of our P/S install, on load the whole reservoir is twisting causing the belt to slip and squeal.
Do we need a bar and bolts to bolt to the front and to the engine somewhere to stop it twisting and brace it properly or have we fitted it wrong ? any help would be awesome as this is the last piece of the puzzle Cheers photos for reference ![]() ![]() |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Power steering install issues - help please
Looks like you have part of a power steering bracket there, you might be missing a piece. Maybe, I dont know, just me.
ok thanks chaps, its now obvious we're missing a vital part !!
60-66 Nut
Those brackets are for a small block with the short water pump. I believe the OP has a long pump.......it's a little hard to tell in the pics.
#6 | |
60-66 Nut
It appears that you have the long water pump on your small block. With the long pump, the power steering pump mounts in part off of the boss on the lower drivers side of the ;pump. There are 2 or 3 different variations of the correct brackets. One of those is what The Rocknrod posted. Does that boss have threads or is it a smooth bore?
I only see one groove pulleys.
How are you driving your alternator??? Read this thread here, lots photos. http://67-72chevytrucks.com/vboard/s...power+steering Last edited by andyh1956; 02-04-2018 at 10:53 PM. |
that does look like the pump for the short water pump setup though does it not
ron |
60-66 Nut
It is a little hard to tell in the pic but to me it looks like a butchered long water pump bracket.
Yeah that's a short pump, no boss for a long pump brkt to swing on. He has a FUBAR of parts & only one belt. It has to travel to the right side & hang the alt pulley over there.
I think we will have to source a complete system for him & send over there. I spent two weeks in England & didn't see the 1st salvage yard. That's just plain Wrong! ![]() |
