Aftermarket distributor
I have read most of the MANY posts on this and thank you for your patience and advice.
70 K10/350/3ott/1406 Edelbrock - daily driver My truck has a GM HEI distributor - came to me that way. Because it sits higher the cab rubs against cap. Obviously not a good thing. My plan - put a point style distributor that sits lower and put a kit in (petronix type). Curing the clearance and keeping the electronic ignition. My questions - this is my daily driver - I am not looking for lots of horse power, just drivability. I also don't want to have to order special parts when I have to do a tune-up. Suggestion of what to buy? Thank you for reading the long post. |
![]() Join Date: Dec 2013
Re: Aftermarket distributor
Just find a low hei cap with the divorced coil , mid to late 80's Camaro/Impala if I remember right
Factory V8 truck. I do believe the 4x4 engine mounts are a little higher, creating my problem.
Grumpy - will resort to if I have to. An option i had not thought of. Would rather install a kit and keep it clean and simple. Just looking for the best kit for a DD. Thank you |
#4 | |
CaptRMW, I believe you are mistaken. The swap from an I6 to a SBC in the rear mounted location is a perfectly acceptable way of replacing an engine. I just did it last month. And used an HEI distributor with plenty of room. It also required no modification of crossmembers, trans mounts or driveshaft. I did this because it is way less expensive and it works just fine. Every 4x4 truck with a V8 has this setup and it works just fine. Also Elvis has a K10. He cant move the engine forward if it's 4x4. It wont work. OP, i used an HEI distributor from Speedway motors and I did not have any issues with clearance. Maybe it is smaller than an original GM dist. I don't know because I didn't have one to compare it to. That's just my experience. |
