02-06-2018, 05:17 PM | #1 |
292 Fuel Injection?
Has anyone successfully used a throttle body with the GM/Chevy 292?
02-06-2018, 06:21 PM | #2 | |
Re: 292 Fuel Injection?
There is a special forum called ''Blown and Injected'' on the Inliners International website: www.inliners.org that is specific to this topic. The hot running thread is about a Pontiac OHC 250, which has a different head than the Chevy 230/250 L6s. Also -- sadly-- his photos have disappeared -- it's a long running [five year old] thread. I run an Edelbrock 1404, 500 CFM 4 Bbl, w/Offy 5416 and Clifford headers on the 292 in my '68 Chevy C/10 stepside. Fuel injection on a later project interests me.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-07-2018 at 12:22 AM. |
02-06-2018, 08:08 PM | #3 |
It would not be difficult to machine an adapter to go from the square shaped inlet of the Clifford or Offenhauser intake and allow the standard Holly 2 or 3 bolt throttle body to sit on top.
Will check out the Inliners International website: www.inliners.org for more info. Thanks On a different question, found a number of references to GM/Chevy 292 dual cast iron headers, but all the sources I found were sold out. Are these dual cast iron headers easy to locate and are they worth the money? |
02-06-2018, 08:55 PM | #4 | |
Yes. https://www.12bolt.com/store/p153/Ex...0-250-292.html https://www.12bolt.com/292-turbo-efi.html Last edited by Grumpy old man; 02-06-2018 at 09:02 PM. |
02-06-2018, 08:58 PM | #5 | |
Tom Lowe would be an excellent source to ask your earlier FI questions. He's also into turbocharging these L6s.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-06-2018 at 09:13 PM. |
02-06-2018, 10:38 PM | #6 | |
will work with you 292. You can use Offenhauser Single-Quad Intake Manifolds 5416-LK. I have seen VW Bugs using the 600hp version of the 400.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI Last edited by Rufas; 02-06-2018 at 10:39 PM. Reason: Spelling |
02-07-2018, 11:12 AM | #7 |
Thanks for the information.
