01-20-2013, 10:36 PM | #676 | |
Daring to be Different
Re: Project - '69 4x4 named "Patches"
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
01-20-2013, 10:44 PM | #677 |
Nice work Shannon. You will be out playing in the mud before you know it.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
02-05-2013, 12:27 AM | #678 |
I'm so jealous! Wanting to switch my 69 C20 over to 4X4......And would so love to be back in Canton. Would settle for Ball Ground. LOL
02-08-2013, 09:03 PM | #679 |
2 things...
1) Semper Fi and thanks for your service 2) Great project and of course, that MC attention to detail is outstanding |
02-08-2013, 10:14 PM | #680 |
Nice work! The truck is looking good.
Posted via Mobile Device |
03-10-2013, 11:17 PM | #681 | |||
The Few, The Proud
Thanks for the comments everyone. I appreciate the support. I've been trying to get back in the groove and work on the truck some more here lately. I'm running a small cap HEI dizzy which requires an external coil. Due to clearance issues with the firewall I really didn't want to mount the coil to the engine or anywhere else in the engine bay for that matter. So after some brainstorming I came up with the idea to mount the coil inside the cab. I found a hose clamp that would hold the coil and plug welded it to a piece of flat bar. I found what I thought was the best place inside the cab to mount the bracket and then welded 2 bolts to the firewall. I'm not installing a radio in the factory location so the coil should have plenty of clearance. The end result. It's kind of an optical illusion, but the top of the coil clears the firewall and the coil wire will go on with no clearance issues. Sorry for the fuzzy pictures. I plan on running the coil wire through the firewall using the hole where the washer hoses go. I'm rerouting the washer & pump hoses so that hole works out well. Next, I tackled mounting the hydraulic master cylinder for the clutch. I planned early on in my build to eliminate the factory mechanical linkage. After some research and reading other builds I settled on Wilwood's 3/4" bore master cylinder. Started out by marking a template on the firewall and drilled some holes. Next, I had to connect the master cylinder rod to the clutch pedal arm. I ended up using a 5/16 threaded yoke, a coupling nut and some 5/16" solid round rod. I threaded both ends of the rod and then mocked up the assembly. After I got everything lined up I marked and drilled a hole in the clutch pedal arm and installed a roll pin. Final shot before I took it all apart again.
Shannon |
03-10-2013, 11:42 PM | #682 |
1 thing at a time is progress.
Your doing good grasshopper!
Alan
Philippians 2:14-16 |
03-11-2013, 12:18 AM | #683 |
Chevy Enthusiast
Very nice!
Were you planning on using one of these for the coil wire?
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
03-11-2013, 11:44 AM | #684 |
The Few, The Proud
Thanks Alan.
No. I'm using the factory coil wire and will run it through the firewall hole that the windshield washer and pump hoses go thru. I'll get a blank grommet and punch out the center just big enough for the wire. Basically, the coil will be on the opposite side of the firewall directly behind the distributor. See the attached picture for reference.
Shannon |
11-15-2013, 08:50 PM | #685 |
Updates??? Been a while.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-02-2013, 09:07 PM | #686 |
The Few, The Proud
Nothing to write about, still stock piling parts when I can. Our company is in the middle of relocating to a bigger facility and as operations mgr guess who is carrying the load. Also, my wife and I are expecting our second child, a little boy, in February. Needless to say Patches has been put on the back burner for a little while. I've been catching up on builds on here trying to get motivated again.
Shannon |
12-02-2013, 09:11 PM | #687 |
What our quality time yesterday didnt motivate you?
Alan
12-02-2013, 09:49 PM | #688 |
Shloooooong bed member #2
Shannon,
Congrats on the little one. And the new facility.
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
12-02-2013, 10:04 PM | #689 |
The Few, The Proud
It definitely helped.
Thanks David.
Shannon |
12-02-2013, 10:47 PM | #690 |
Shannon,
I stock piled parts for 5yrs before getting back to working on my project, just saying it will always be there when the time is right ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
12-02-2013, 11:20 PM | #691 |
Nice to know your still out there! Congrats on the new little one too.
12-03-2013, 12:57 AM | #692 |
Family first, then the truck for the family, congrat's.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
12-03-2013, 10:57 PM | #693 |
Congrats, im stock piling too... Parts, not kids though!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-04-2013, 05:22 PM | #694 | ||
The Few, The Proud
You're right Gary. That's what I keep telling myself and everyone else who asks about it. At least it's not rusting out in a field somewhere. Quote:
Thank you. No doubt, family first. I replied in your build thread, but I'll tell you here as well. Welcome home!!! Is 2014 the year to complete yours?
Shannon |
02-27-2014, 03:30 PM | #695 |
Under Construction
Shannon, hope you, and the family are doing great!!
Take care Buddy!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
02-27-2014, 04:05 PM | #696 |
^^ Ditto that!
02-28-2014, 03:21 PM | #697 |
well, we are building a master suite addition this spring, then patio and then my garage gets built...
Funds will be low but at least i'll have a good man cave garage to work on it... planning a 28x34 polebarn with heat...
03-23-2014, 03:35 PM | #698 |
Shannon ,I just found your build and went thru all 28 pages ,you and Alan do great work .Congrats on the new addition to your family .
01-03-2015, 07:33 AM | #699 |
You still around????? Your build is awesome brotha! To put it into perspective, I'm not fond of these year trucks and I read your entire build thread, it kept me engaged. Like Alan, you too, do very good explaining and I love that in a build thread!!! COME BACK.. We need more!
PS Alans thread brought me here. Saw you in multiple pictures/comments and figured I'd read yours too! PSS Keep up that damn fine work! Mike |
02-09-2018, 03:30 PM | #700 |
Came back to check this out - how's the build?
