Old 02-10-2018, 04:28 PM   #1
Ghost's68
Ghost's68's Avatar
Need help with engine mounts/perches
I’m down to just figuring out what mound to run so I can finally drop my LS3 in. I bought some DD sliders and have them on the block now but the POL perches I bought don’t sit flush on the rail of the truck. Reading the instructions I see it says it might need modification to make them work. I don’t want to bend my rails if I don’t need too. I was thinking of getting the CPP and even buying the 73+ style.
What’s the best approach here considering I’ll be running LT headers?....
Ghost's68 is offline   Reply With Quote
Old 02-10-2018, 06:18 PM   #2
Clyde65
Clyde65's Avatar
Re: Need help with engine mounts/perches
Just use the stock perches.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-10-2018, 06:56 PM   #3
Ghost's68
Ghost's68's Avatar
The PO hacker toghether a 5.3 swap and used what appeared to be the old perches but once I got the old motor out and i inspected the perches there was some damage to them and decided to just grab some new mounts. Plus I’m not sure if they were the SBC or 6cyl. Here’s a pic
Old 02-11-2018, 03:21 AM   #4
Frankie P.
I just installed my L92 on my frame and used the POL engine perches. They fit well. Had to enlongate one hole on driver side and grind just a tiny bit in the frame edge so the holes line up. What I did was, leave perch bolts loose and the slowly torque them down until they fit flush.
Frankie P. is offline   Reply With Quote
