Old 02-06-2018, 05:36 PM   #1
brian1971
brian1971's Avatar
Looking for a 1968 and up Muncie M22
Looking for a 1968 or up Muncie M22,must be a M22.Don't need shifter for it just the transmission.
Thanks Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 02-06-2018, 07:19 PM   #2
72ironmike
72ironmike's Avatar
Re: Looking for a 1968 and up Muncie M22
What are rock crushers going for these days ?
72ironmike is offline   Reply With Quote
Old 02-06-2018, 09:41 PM   #3
brian1971
brian1971's Avatar
There all over the place but a good rebuilt one could be 1,100-1,300.If they need rebuilt can get expensive if it needs gears.Also the 26 fine spline onse are more desirable.
Old 02-09-2018, 09:37 PM   #4
bill3rail
bill3rail's Avatar
I do not know what it is exactly, but a friend has a Muncie in his garage. I saw it, but I know nothing about them. You may have to help me identify it.
I will try to take pictures of it and post it here.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 02-09-2018, 10:02 PM   #5
brian1971
brian1971's Avatar
Yeah there are a few ways to identify them,just try to take pics of all numbers you see there are numbers in 3 to 4 different places.Also take a few pics of input shaft.
Old 02-09-2018, 10:08 PM   #6
bill3rail
bill3rail's Avatar
Check your PM's.
Will try to get there tomorrow. It is in the rafters above his garage. Will be a challenge but I'll get up there somehow.
Old 02-09-2018, 10:53 PM   #7
The price can depend on what vehicle the numbers go to. The one for my '67 is correct for a '65 GTO, so could bring bigger money to someone who has to have it for their high dollar car
Old 02-09-2018, 11:30 PM   #8
rsavage
rsavage's Avatar
Pretty sure Pontiac didn't offer an M22 in a 1965 GTO not even as an option. M20 or M21.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-10-2018, 12:01 AM   #9
RogerKoop
RogerKoop's Avatar
All M22 had straight cut gears. Used only on GM Hi Performance cars
Roger Koop
RogerKoop is offline   Reply With Quote
Old 02-10-2018, 08:08 AM   #10
rsavage
rsavage's Avatar
You can buy a brand new super case M22 for $2400. Unless you are really fortunate, a 50 year old 4 speed is more than likely going to need some work. You can also find some that have been professionally rebuilt, but they aren't cheap either.
https://www.midwestmuncie.com/produc...-rock-crusher/
They also offer rebuilt units but you have to have a core or there is a $500 core charge
https://www.midwesttrans.com/M21,%20...nsmission.html
1961 C1 Corvette
2021 Durango RT 5.7
Old 02-10-2018, 11:17 AM   #11
bill3rail
bill3rail's Avatar
$2400.00? That to the uneducated Muncie person like myself seems pretty steep. I guess if that is what you must have then it is it.
Old 02-10-2018, 01:23 PM   #12
bill3rail
bill3rail's Avatar
Friend was out shopping for hand cannons this morning so I was unable to get over there. Will try for Monday morning.
Old 02-10-2018, 10:11 PM   #13
Nestevec
Nestevec's Avatar
Here you go. Not mine, but 45 minutes away. If your interested I can go look at it for you. Came out of a 68 Chevelle.
https://lincoln.craigslist.org/pts/d...451528215.html
Nestevec is offline   Reply With Quote
Old 02-10-2018, 10:16 PM   #14
Eagle9502
There's a guy that my Dad has bought several rebuilt M20s and M21s from. Came across him at swap meets. I believe he's in Pensacola. At the swap meet last week he had a couple M-22s. His name is Matthew 954-985-0264.
Eagle9502 is offline   Reply With Quote
Old 02-11-2018, 08:28 AM   #15
Grumpy old man
Grumpy old man's Avatar
What bell housing are you planning on using ? The out put hole of the bell housing must match the trans , The '67 stock bell housings work the later bell housings have a larger output hole which results with the car muncie's relying only on the 4 bolts and can crack the muncie mounts .
Old 02-11-2018, 11:02 AM   #16
Husker
Husker's Avatar
Summit has a ring that works for that Problem.
Ron
https://www.summitracing.com/parts/add-716078
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 02-11-2018, 05:54 PM   #17
bill3rail
bill3rail's Avatar
Still have not climbed up in the garage rafters however, I was told it came out of a 66 GTO 389 Tri-Power. If that helps at all.
Obviously the casting numbers will tell the truth 100% when I get them.
Old 02-11-2018, 06:20 PM   #18
Nestevec
Nestevec's Avatar
A 66 GTO came with either the M20 or M21.
Old 02-11-2018, 06:46 PM   #19
bill3rail
bill3rail's Avatar
I saw that online but memories do fail and my friend is in his 70's...
