Old 02-10-2018, 02:07 AM   #1
frankyjoet
Unhappy a/c hose from condenser
I have been searching for a/c hoses from the condenser to the compressor. I need help to find them. I have a 73 gmc 350 4 spd granny. The only hoses that are missing are these 2 hoses. I think they are the low side and high side. Any help on where to find them would be appreciated.
frankyjoet is offline   Reply With Quote
Old 02-10-2018, 07:25 AM   #2
homemade87
Re: a/c hose from condenser
Go to rock auto . I am usually surprised what they have . Looks to be a one piece unit on the compressor . See if this is what you are looking for .
http://www.rockauto.com/en/catalog/g...rant+hose,6900
homemade87 is offline   Reply With Quote
Old 02-10-2018, 06:27 PM   #3
frankyjoet
Unhappy Re: a/c hose from condenser
Homemade87, i bought the same hose shown at rockauto at Auto zone. The hose or hoses are coming from the condenser. On the condenser i have two tubes that are located at the top drivers side. I believe they are 1 high side and lower side. My a/c system is factory not aftermarket. Thanks for any help.
Old 02-10-2018, 08:09 PM   #4
Dead Parrot
IIRC, on my 75, one hose from the condenser coil(in front of the radiator) goes to the compressor(one side of the hose set in question). A second small diameter hose exits the other condenser coil connection, goes over the radiator and to the expansion valve. The other half of the compressor hose set runs from the dryer over the motor and to the compressor.
You wind up with 2 hoses, one single smaller diameter hose and a double hose set that hooks to the back of the compressor.
Dead Parrot is offline   Reply With Quote
Old 02-11-2018, 07:43 AM   #5
homemade87
Heres a picture of the system for your truck . Coming off the condenser there seems to be an intermediate tube between both hoses . Is this what you are talking about . They do not show it as an available part .
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=186
Old 02-11-2018, 12:52 PM   #6
frankyjoet
Red face Re: a/c hose from condenser
homemade87, that's exactly what i am searching for the coil part between the compressor and evaporator lines. i called lcm and they could not help me. Now i have to search part yards. Thanks for your help. Will reply when i find them. 73 gmc ride.
Old 02-11-2018, 04:39 PM   #7
85/Silverado
85/Silverado's Avatar
I made my own and they still don't leak after a year. I bought a small kit that install's the ends and the tool came with it to crimp the ends. I'll try and look up the kit if I can.
85/Silverado is offline   Reply With Quote
Old 02-11-2018, 06:49 PM   #8
hatzie
Moderator
hatzie's Avatar
I made my own but I was installing a Sanden (HT6?) from a 1998.
You can carefully cut through the crimp sleeves and remove the hoses then place the hard lines where they need to go and crimp on new R134a barrier hose.
If you have a 73-80ish Harrison A6 compressor you may have a muffler in the original compressor hose fitting. You'll need to get it removed and have a barbed end for fitting the hose brazed in place of it.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 02-11-2018, 08:13 PM   #9
frankyjoet
Hi hatzie, thanks for the info. My 73 gmc 350 rv cam granny 4spd saginaw 2500 never had air, so i am installing as many new parts that will fit from Autozone and elsewhere. My compressor is a NEW 4seasons/everco from AZone. A new hose assembly, a new accumulator , an expansion valve and a new condenser. New electric parts a/c sw, and resistor plug. New heater/ac core and fan motor. From the yard an evaporating housing, a factory a/c box with all the controls and a evaporator from a '83 chevy pkup. Also from same 83 pkup a heater a/c control assembly. The part that i need is a coil looking line that i believe connects to the evaporator and the compressor hose. Not available a LMC. Thanks a again for your help. Will reply when i find these parts.
Old 02-12-2018, 12:10 AM   #10
hatzie
Moderator
hatzie's Avatar
You need some hard lines... Salvage is probably the ticket. Don't be afraid to look at the B-Body cars and wagons like the Caprice, Impala, Parseinne etc. The G-series vans too.
Old 02-13-2018, 06:42 PM   #11
frankyjoet
Smile Re: a/c hose from condenser
Hi hatzie, i found the missing parts today 2/13 for my 73 gmc c2500 from a 77 c10 at a bone yd. They are in good shape just needs cleaning and o rings. I also found the brackets for the compressor. Thanks to all for your help. You guys are awesome. frankyt
