Old 02-12-2018, 03:36 AM   #1
Rufas
Rufas's Avatar
Vin number on frame?
I've read here that part of the VIN number is stamped on the drivers side of the frame near the power steering pump. I've look in that area and can't find it.
Is it stamped on the outside of the frame or the inside of the frame.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 02-12-2018, 04:30 AM   #2
my04
my04's Avatar
Re: Vin number on frame?
Stamped on top of the frame adjacent to or slightly forward of the power steering pump, #'s are parallel with frame rail. May have to wire brush a little to reveal it. Mine was not noticeable either until wire brushing and sanding lightly.
my04 is offline   Reply With Quote
Old 02-12-2018, 08:24 AM   #3
notsolo
notsolo's Avatar
Stamped on top of frame, near ps pump toward cab on my 71, probably hidden by inner fender. Also on frame under cab, about the center top.
notsolo is offline   Reply With Quote
Old 02-12-2018, 09:47 AM   #4
CG
BlahBlahBlah
I don't know the definitive answer on this, but Ive read on here many times that not all the GMC's have frame stamped partial vins.
Old 02-12-2018, 02:04 PM   #5
extd56
extd56's Avatar
My 67 GMC had no numbers on the frame
extd56 is offline   Reply With Quote
Old 02-13-2018, 10:49 AM   #6
chewychevy67
My 67 gmc did not have any either
chewychevy67 is offline   Reply With Quote
Old 02-13-2018, 02:42 PM   #7
Rufas
Rufas's Avatar
Inner fenders have been removed. Frame has been cleaned and painted. I still can't see any numbers. I can easily see the top of the frame in the area ps pump and to the cab.
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 02-13-2018, 04:52 PM   #8
B. W.
B. W.'s Avatar
I have a '71 GMC with no frame numbers. I'm guessing not all GMC's had them? My '70 Chevy is stamped.
B. W. is offline   Reply With Quote
Old 02-20-2018, 07:48 PM   #9
Z10
Z10's Avatar
72 with a frame stamp near the power steering box as described.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 02-20-2018, 07:51 PM   #10
Rufas
Rufas's Avatar
Is that on the top, inside, outside oe bottom of the frame?
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 02-20-2018, 10:46 PM   #11
Z10
Z10's Avatar
top of the frame.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
