Old 02-13-2018, 01:11 PM   #9
60-66
60-66's Avatar
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Yelmer , check your part number 3834112 , comes up as the rod assembly FOR the booster. The booster assembly is 3843823-assembly manual or 3848503 1966 parts book, for 1964-1966 and Bendix only.
More info on the 618082 master , this is the Bendix master cylinder, two companies were making master cylinders for GM at this time. The other was Delco / Moraine . Both are assembly line correct. Also look in the assembly manual , it shows the screw on top master cylinder. The date I believe is calendar days of the year out of 365 days ,yours 66th day of ? 1966 ? I have some with 146 and 277.
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
