Old 02-12-2018, 08:36 PM   #26
Nh4clo4
Nh4clo4's Avatar
Re: Project High School Reunion
Got the new dash cluster and glove box cut out today
Nh4clo4 is offline   Reply With Quote
Old 02-12-2018, 09:43 PM   #27
Nh4clo4
Nh4clo4's Avatar
Here is the back side of the glove box, I put a spot for the SPID and the drink circles
Old 02-13-2018, 01:16 PM   #28
Nh4clo4
Nh4clo4's Avatar
Here is a shot with the gauges in
Old 04-11-2018, 06:36 PM   #29
Nh4clo4
Nh4clo4's Avatar
Got most of the interior out and got all the guts out of the doors.
Old 04-22-2018, 06:24 PM   #30
Nh4clo4
Nh4clo4's Avatar
With the nice weather, I got the inner fenders and core support painted.
Also fully stripped the cab, no rust and will be all original gm metal. Even the window channels don’t even have a start if rust.
Old 08-15-2018, 07:37 PM   #31
Nh4clo4
Nh4clo4's Avatar
Been really busy with work. Got the cab all ready for media blasting. There were holes from a cb, aftermarket gauges, switches, dual fuel tank switch, old floor shifter hole from my youth, and several firewall holes from an aftermarket a/c.
Got the cab off, started tearing the front end off
Old 08-31-2018, 06:32 PM   #32
Nh4clo4
Nh4clo4's Avatar
Got the frame sandblasted and primed, about a dozen more parts, and I can start re assembly 🎉
Old 09-06-2018, 07:13 PM   #33
Nh4clo4
Nh4clo4's Avatar
Got the cab back from the media blaster, got it blasted inside and out and epoxy primer.
All gm metal, now the hard work begins
Ed
Old 10-26-2018, 02:57 PM   #34
Nh4clo4
Nh4clo4's Avatar
Finally had time and decent weather to paint the frame, I can start reassembly soon!
Old 10-26-2018, 04:10 PM   #35
landarts
landarts
Very nice job on the truck! I really like your color choice, sort like the original Copper Poly but much darker. Is that your CNC machine in the picture, if so what type?
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is online now   Reply With Quote
Old 10-26-2018, 05:12 PM   #36
Nh4clo4
Nh4clo4's Avatar
Ez-router
It’s amazing what you can do with them
Thank you
Ed
Old 10-28-2018, 06:51 AM   #37
72 tigger
72 tigger's Avatar
Nice progress- you’re doing it right
72 tigger is offline   Reply With Quote
Old 01-19-2019, 05:31 PM   #38
Nh4clo4
Nh4clo4's Avatar
Thanks tigger,
I have been swamped with work and haven’t been on here or the truck.
Finally spent a few days on her and I am back on 4 wheels!
I put cpp dropped spindles and drop rear springs.
Now I need to get the engine tranny and brake lines in.
Old 11-29-2020, 12:00 PM   #39
Nh4clo4
Nh4clo4's Avatar
Well after a long hiatus due to a heart attack last year, finally have time to to get back on it, got the engine, trans, and drive shaft installed.
Old 11-30-2020, 01:37 AM   #40
cornerstone
cornerstone's Avatar
Good work! Glad to hear you made it through that ordeal alright. One of my best friends had a double bypass last year, and feels so much better now that his pipes have been cleaned out his blood flow is so much better. I hope you can say what he says, "I feel like a new man"... I'll be watching for more updates!
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-30-2020, 08:40 PM   #41
Nh4clo4
Nh4clo4's Avatar
Thank you for the support, it made me realize I better finish this before my family needs to deal with it!
Old 12-05-2020, 07:15 PM   #42
Nh4clo4
Nh4clo4's Avatar
Got all the engine accessories on, minus carb and distributor.
Pulled it outside a rinsed the dust off. Now I can cover it and get the cab ready to put on
Old 12-05-2020, 08:31 PM   #43
RCbowtie69
RCbowtie69's Avatar
Looking good !!!! Keep the pictures coming & the progress going forward & keep on truckin'.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 12-05-2020, 08:41 PM   #44
Nh4clo4
Nh4clo4's Avatar
Thanks, I had a hiatus for health, and am feeling really good and getting more enthusiastic on it
Old 02-09-2021, 08:23 PM   #45
Nh4clo4
Nh4clo4's Avatar
Cab is getting close for paint and install in the frame,
Inside and top is block sanded and ready for paint.
Made a cart to get it off the ground so I can get the bottom half block sanded and then paint!
Old 02-10-2021, 12:07 PM   #46
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Getting paint on the cab and it back on the frame is such a big motivator. Glad you are still working on it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-10-2021, 01:32 PM   #47
Nh4clo4
Nh4clo4's Avatar
Yep, gotta finish it this year. It is so close, all the body panels are in primer, so once the cab is done it should go faster, there is a lot of real estate on the cab to prep.
Old 02-27-2021, 07:30 PM   #48
Nh4clo4
Nh4clo4's Avatar
After several weeks of sanding, finally got the cab painted and ready to put it back in place
Old 02-27-2021, 07:30 PM   #49
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
I recognize that color - fabulous!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 02-27-2021, 07:50 PM   #50
72 tigger
72 tigger's Avatar
Looks great!
71 C10
72 K20
72 K10 Super
Kirk
