Old 02-11-2018, 01:43 PM   #1
oneshot
oneshot's Avatar
Asymmetrical gauge cluster(mock up)
Something the stock guys won't like, but I wanted something different. I will make it out of aluminum and set it in the stock plastic outer bezel.
oneshot is offline   Reply With Quote
Old 02-11-2018, 01:55 PM   #2
ga-stepside
ga-stepside's Avatar
Re: Asymmetrical gauge cluster(mock up)
I like it.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 02-11-2018, 04:33 PM   #3
notsolo
notsolo's Avatar
Nice set up...Woodgrain looks nice as well, do you have the turn signals included in there somewhere?
notsolo is offline   Reply With Quote
Old 02-11-2018, 04:58 PM   #4
Looks nice and functional as well.
Old 02-11-2018, 05:09 PM   #5
oneshot
oneshot's Avatar
I haven't drilled for the turn signals, high beam or switch LEDs. I'll do that when I make the good panel out of aluminum.
Old 02-11-2018, 05:09 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Looks cool. Where are the headlight and wiper switch mounting locations? I'm thinking of doing mine non-stock as well, but I'll put in a speedometer that only goes to 80 MPH. No point in going faster than that, especially pulling a trailer.
~Steven
Simi Valley, CA
Old 02-11-2018, 10:00 PM   #7
oneshot
oneshot's Avatar
Headlight and wiper switches are two of the four toggles mounted below the tach.
Old 02-13-2018, 12:21 PM   #8
bigmac73
bigmac73's Avatar
my thought is It is your truck do it how you want ...
and it looks good
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-13-2018, 01:42 PM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
A different arrangement is one way of avoiding eye fatigue. But have you tried reading it at night with the wheel in place? Are you sure you're not hiding or obstructing any gauges or indicators?
Old 02-13-2018, 01:47 PM   #10
davepl
davepl's Avatar
If you want extra credit align the gauges so all the needles point UP when everything is in the OK range, then you can tell at a glance if anything needs your attention!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-13-2018, 02:34 PM   #11
Coley
Coley's Avatar
..another cool thing would be to include some sort of center aperture/cut-out for something like a back up camera screen, dash cam or something like your smart phone/device, etc. Something that would be considered a little unusual or advanced for an older truck....but with a very modern swing to it.
If you don't have anything chosen yet it could be 'sized' to correspond with a nice GM logo or equivalent until a device was found and chosen.
....just thinking out loud here.....'spit balling' so to speak.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-13-2018, 03:18 PM   #12
oneshot
oneshot's Avatar
Thanks for the ideas guys. Until I can get it started (soon) it's just a mock up. I need to start it and set the cab to see what the cluster looks like behind the steering wheel.
This is how far I am (photo below).
