Old 02-06-2018, 02:36 PM   #1
Grumpy old man
Grumpy old man's Avatar
Zinc additives , Here's a sale for you
Shell X-100 classic oil and zinc additive are on clearance at Autozone , They normally run $18-$20 each now at Autozone $3.97 in store only
https://www.shellx100oil.com/classic...oils-additives
Old 02-07-2018, 10:00 AM   #2
randy.powell
Re: Zinc additives , Here's a sale for you
Good tip, Grump! Going there after work...
randy.powell is offline   Reply With Quote
Old 02-07-2018, 10:51 AM   #3
Grumpy old man
Yeah , I like the metal cans and seen them sell on ebay for $20.00 empty .
Old 02-13-2018, 08:07 PM   #4
zosoppp
Managed to score 4 cans at $0.97 each here in NJ today. (2each at 2 stores).
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 02-13-2018, 09:45 PM   #5
CST10
CST10's Avatar
I’ve been searching down here for a can, nobody carries it.
I wanted one for my Shell collection, yes I work for Shell and can’t get one. Lol. Ironic isn’t it.
Anyone wanna sell me one?
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 02-14-2018, 02:42 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Thanks for the heads up, Grumpy.
I bought 2 quarts of Oil Stabilizer at .97 cents each at my local A/Z. They were out of the zinc additive, but the store guy called around for me. No luck, though.
So what do I use oil stabilizer for anyway?
He also said Rotella SAE 30 still had the right amount of ZDDP. I said I didn't know Rotella came in straight weights, I thought it was all 15W-40 but there was a couple gallon jugs of 30 weight on his shelf.
So is it true that Rotella straight weight oil still has sufficient amounts of ZDDP for our pre-catalytic/hydraulic cam purposes?
Old 02-14-2018, 07:41 PM   #7
Shinysideup
Shinysideup's Avatar
Thanks Grumpy!!!
I went in for the zink but a huge number of items were $.97
Heres my haul from 5 stores, only took what I could use,much more left!
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 02-14-2018, 08:42 PM   #8
Grumpy old man
Looks like you scored You probably saved a couple hundred just on the Shell additives ? I always check the clearance for the deals I'm going back to see if the gear oil is on clearance here .
Old 02-14-2018, 08:48 PM   #9
Grumpy old man
Pm your address and I'll send you one In a week or two
Old 02-14-2018, 08:49 PM   #10
Shinysideup
Grumpy, thats not gear oil, its oil stabilizer(black bottles). Only the "additive" section had clearance. I did score 150 quarts of oil two years ago for $1/quart when they closed out some items at end of year.
._____________
Old 02-14-2018, 09:35 PM   #11
CST10
CST10's Avatar
Thanks a grumpy. I PMed the info to you.
I appreciate it.
MyToys:
Old 02-15-2018, 03:48 PM   #12
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Thanks for the heads up Grumpy. Went to both stores here in Blount county,only had one can. This is what I like about this forum,members helping others.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 02-15-2018, 04:25 PM   #13
Warrens69GMC
Warrens69GMC's Avatar
nano gear lube 75w-90 synthertic is 5.00/qt
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 02-15-2018, 09:34 PM   #14
CST10
CST10's Avatar
Whoop whoop, I found 2 cans at an autozone in another town I was in today. Sweet.
MyToys:
