Vintage Evil
Looking for suggestions on a weatherproof electrical box
As the title says... Im looking for suggestions on a weather proof electrical box that i can mount under the body to hold Fuse, relays etc for my fuel pump as well as any aux power i run to the rear for lighting or whatever... something with a removable lid but yet will keep the salt/chemicals off those components... I used a plastic electrical conduit box similar to the picture attached on previous projects but the shape is wrong for what im trying to accomplish here..
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: Looking for suggestions on a weatherproof electrical box
I used a box like this on most of my big trucks and it seems to hold up well. Most trailer sales places and Napa have them
https://www.delcity.net/store/Stud-T...iABEgI0TPD_BwE
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
![]() Join Date: Aug 2014
try a electrical supply company or someone who does irrigation!
Bussman makes a line of fuse boxes that can hold relays, fuses and circuit breakers. Waytek wire is the cheapest place I've found them: https://www.waytekwire.com/products?pSearch=15303
There are 6 options for the different input/output configurations. Box is completely sealed. Uses mini fuses (type ATM) and the relays found in most modern vehicles (ISO 280 micro relay).
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Vintage Evil
Thanks for the info all who have replied... Where have you been mounting these?
I made a mount and put mine next to the battery, attached to the fender.
Vintage Evil
I was thinking somewhere mid body or towards the rear... so i could just open it up and add another wire to the distribution block or add another relay if needed...
I haven't heard of people mounting these under vehicles before.
If you do, you'll want to mount it as high as possible with a shield in front of it to keep anything from spraying or hitting it.
Vintage Evil
Yep thats the plan... thinking behind the step up for the "bed" area...
We use LB fittings under the trailers that we build to transfer electrical connections through the floor (we run our wiring under the trailer in conduit and make penetrations where needed). Have never had any issues.
-Bruce 1971 K5 Blazer 4WD ![]() |
Vintage Evil
i found this... not sure it will hold up to the heat under there though...
![]() https://www.amazon.com/gp/product/B0...EEY9IL19R&th=1
![]() Join Date: Jan 2003
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
Vintage Evil
Not quite what i had in mind... but not bad...
Find these in the salvage yards on Corollas and Camry +other Toyotas
Headlight relay box https://www.ebay.com/itm/1997-1998-T...1Z4XnT&vxp=mtr
#15 |
Here is what i usually use . https://www.waytekwire.com/item/4634...i-Fuse-Panel-/
Great product and is well sealed . Just careful when ordering pay attention to the Data sheet . this fuse box is sold in a few ways depending how you would like it configured . and Pins have to be ordered separate. |
#16 | |
https://racespeconline.com/collectio...=5655593582630 hope it helps. |
#17 |
#18 |
https://www.facebook.com/Waterproof-...1112501215493/
This is a Bussman box but this guy wires it however you want it and sends it with fuses and relays installed. Everything about it is high quality.
![]() 1972 GMC Jimmy 6.0/4L65 1972 Chevrolet long bed 1/2 ton |
