Old 03-05-2015, 10:39 PM   #26
JPsChevy
JPsChevy's Avatar
Re: 73-87 lift/tire combo pics
Originally Posted by 324matt View Post
85 k20.
Skyjacker 2.5 in front with ORD front shackles.
STL Spring 56" rear springs with +1" extra arch and ORD zero rate add a leaf.
Bilstein 5100 all 4 corners.
285/75/16 Michelin LTX AT-2 on 16" GM HD powdercoated wheels
324matt that truck is cool, im really liking the powder coated aluminum rims. did you just cut center out of front caps for hubs?
JPsChevy is offline   Reply With Quote
Old 03-06-2015, 07:39 AM   #27
324matt
324matt's Avatar
Yes. I used a dremmel to cut out the centers for the hubs
1985 GMC K2500. 350/TH400/208. 4:10's. stock.
1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD.
324matt is offline   Reply With Quote
Old 03-11-2015, 10:38 AM   #28
Jaredchevyk20
bump
Jaredchevyk20 is offline   Reply With Quote
Old 03-11-2015, 12:56 PM   #29
68Timber
I know the pieces fit
68Timber's Avatar
Rancho 2.5" lift, spring front and block rear over 33x12.50's
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-11-2015, 05:02 PM   #30
K5owner
4" EZ rides with a block in the rear, braided brake lines, raised steering arm, ORD sway bar disco's, ORD HD shackles, and ORD frame reinforcement. Running 35/12.5/15's on factory rally wheels.
No cutting or trimming.
K5owner is offline   Reply With Quote
Old 03-27-2015, 01:41 PM   #31
3672300
3672300's Avatar
man that 4" with 35s looks almost perfect
3672300 is offline   Reply With Quote
Old 08-02-2015, 03:57 PM   #32
3672300
3672300's Avatar
any pics of 6" with 35s?
Old 02-15-2018, 11:22 AM   #33
stomper
Junior Member
stomper's Avatar
33 12.5 on stock height and wheels
"I was patina when patina wasn't cool."
1973 Cheyenne Super SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
k10, k20, k30, lift, tire
