Preference between Dephi and ACDelco fuel pumps?
Prolly going to swap out fuel pump assemblies on wifes DD '05 Yukon Denali. Anybody have a preference between the two? I assume both have the level sensor, but Delphi pumps appear imo to have a better built float level sensor-thoughts?
EDIT: Delphi not Dephi lol Last edited by gmachinz; 12-02-2017 at 02:01 PM. Reason: Spelling in title |
![]() Join Date: Sep 2005
Re: Preference between Dephi and ACDelco fuel pumps?
Dephi makes tbe ac delco pumps last i was told but my locka dealer
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
I work at a small independent shop, we will only install delphi pumps, we put an aftermarket pump in and the car didn't make it a mile down the road and it died. Bad pump. In fact my pump went out about 2 months ago and I put a delphi in
I put a Delphi in my 89' K5. It was a little sensitive to the electrical path though. PO did some type of splice at the electrical connector to the pump. I had to re-pin the connector to make a more "solid" connection and got rid of the soldered wire connection.
No issue since repair. I "think" AC Delco was subbed out at some point and built to "GM" specs...but still 3rd party. Don't know if that changed at some point, but definitely there are questions about a genuine AC Delco and subbed out AC Delco. I'd go with the Delphi one. Dealer put in a new pump in my 04' Yukon many, many miles ago...still going strong at 165k. And by strong, I mean....it runs.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
driving is in my blood
There are 3 levels of ac delco. Cheap, normal, and dealer. Even dealer stuff is made out of country these days. I literally could not get a made in america, new ac delco ac compressor for my 98 over the summer.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
I've had good luck with both Delco and Delphi. I will not install anything but these two brands of fuel pumps. The last time I use a Carter the van was towed back to the shop that night.
I can still count my vehicles on two... wait three hands. |
| Bookmarks |
