Old 02-19-2018, 05:53 PM   #1
MYOUNG
69 GMC C20 Core support repair or replace
My current core support is rusted out on both sides as the truck came with dual batteries. The main mounting points are pretty bad also but the top 2/3 of the core support is in good condition. My question is basically is it better to get a cheaper Chevy core support and cut the bottom off and weld it to my current one or should I drop the extra cash and get the GMC specific one from GMC Pauls and just swap it out.
I have heard that the reproduction ones dont fit as well but I dont know where specifically the issues with the fit are.
Since the bottom of the core support is the same I think it could work but it might not be worth the work if the reproduction one is a good fit.
Has anyone here welded 2 core supports together to make one good one?? I was thinking I could cut it right at the bottom of the opening for the radiator to make the cuts shorter??
MYOUNG is offline   Reply With Quote
Old 02-19-2018, 06:13 PM   #2
B. W.
B. W.'s Avatar
Re: 69 GMC C20 Core support repair or replace
I did a lot of work to my core support, in hind sight I should have sourced another one. IMO, I'd look for a good used one.
B. W. is offline   Reply With Quote
Old 02-19-2018, 07:30 PM   #3
Problems
Problems's Avatar
I was going to list this one here anyway. Just haven’t gotten around to it.
https://milwaukee.craigslist.org/pts...501794501.html
Problems is offline   Reply With Quote
Old 02-19-2018, 08:02 PM   #4
Jason Banks
Jason Banks's Avatar
Can't you buy a chevy one and move the headlight buckets from the old to the new? I thought someone mentioned that one time.
Today I was looking at the one I took out of my truck and replaced with an aftermarket. I still believe it was a good decision to replace instead of repair. Only one side was rusted, but the whole bottom was rusty and would need some patching.
Jason Banks is offline   Reply With Quote
Old 02-19-2018, 09:19 PM   #5
MYOUNG
@Jason. I think you are correct in that you can transfer the headlight buckets. I was trying to avoid shipping a repop GMC one as they are over 100 in shipping. think I can get a Chevy one within driving distance...
@Problems. Thanks for the offer. If I was closer to you I just might go for that. By the time it gets over to my neighborhood it will be 300$.
So then it's a question of Transfer the headlight buckets or swap the bottom. ??
Old 02-19-2018, 09:54 PM   #6
Boog
laying low
Boog's Avatar
Brothers Trucks is in Corona. Is that close enough to drive over and pickup a new one and save shipping? Their's are $269 I think.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-19-2018, 10:57 PM   #7
NorCalC20LWB
I have one off my 72 C20, we’re pretty close. PM me if your interested.
NorCalC20LWB is offline   Reply With Quote
