Can a 72 be bagged?
Can a 72 blazer 4x4 be converted to 2wd and then bagged? I think the rear would have to be leafs or is it possible to put trailing arms on it? Can a leaf setup be bagged?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
wow, going from up to down! totally opposites. but anyways, I would think that just a couple of brakets would be all that would have to be messed around with for the leaf springs. not exactly sure on anything else, I kinda wondered the same a few weeks ago intell I wondered why I was thinking so hard about it, when i realized that my truck is coiled.
On a positive note, anything is possible with the correct designing and imagination.
~Christopher L. Orr 71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc. |
it would be alot easier to switch frames im sure someone would be ready and willing to trade there 2wd frame for your 4wd and front suspention. my .2 -kyle
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Yep you could do it I have been thinking of lowering my k-5 but am gonna wait to see if I can find a 2wd... Once you get the 2wd crossmember bolted in all you would have to do is get a air ride kit for a truck with coil's front and leaf rear should not be too hard...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
o you have a blazer my mistake sorry -kyle
