#14 | |
Re: 1990 Suburban LQ4/4L80E/D60/14Bolt swap
Basically the block was just freshened up and left the bore size, I had thought about swapping to flat top pistons for a bit but never pursued it although I do keep an eye out locally for a good deal on an Lq9 if there ever is one. Honestly I haven't touched the inside of a motor in a few years so its also going to be a bit of a re learning curve and figured i'd just keep it simple for now (not that swapping pistons would be a giant task)
1995 GMC K1500 Suburban 6" Pro comp 35x12.50R17 LSXburb -Build- 1990 GMC Suburban 6.0 Lq4 4l80e np205 D60 14FF 1988 GMC suburban 350ci Sm465 D60 14FF 8" 39.5x15R15 1969 Pontiac Lemans 400ci Muncie 4 speed 2009 Pontiac G8 Gxp M6 |
| Bookmarks |
| Tags |
| dana 60, gmc, lq4, ls swap, suburban 4x4 |
