![]() Join Date: Feb 2008
Re: Sparky's 1978 Silverado Build "Addiction"
Good day. Wanted to go back talk about some of the panel alignment. One of the things that always draws me to a great looking truck, outside of paint etc. is how the lower box line, lower rocker line and lower fender line align - the lighter the paint, the more important I believe it is to have well aligned panels. Here are a few pic's related to what I'm working with, or have fixed on the right and left side.
Pictures: 1. After first installing the front clip, you can see the fender line and rocker panel are quit off, almost a 1/2 inch. Again, having only tacked in the rocker, I was able adjust as necessary and shim fender to where they finally aligned. 2. On the drivers side, I had the same issue and was able to adjust. You can see the slight tear in the rocker panel (just below the vertical yellow line where I got a little aggressive) which will fill quite easily, with a weld. Learning this from my young mentor JaysonB, I will have to make cuts (1) along the yellow line on the rocker and push forward and weld in a small patch panel to give the door, fender and rocker a good clean line all around. (2) Showing the good alignment of fender and rocker panel. 3. Notes are on the picture. However, it'll be a balancing act to not over-correct. There will be a lot of taking of the bedside and putting it back on. Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
| Bookmarks |
