02-25-2009, 12:32 PM | #76 |
1962 C-10
Re: My 65 Build
How did I miss this one?? You're doing some killer work on this truck! AWESOME!
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
02-25-2009, 03:35 PM | #77 |
Its Deja Vu time again
Re: My 65 Build
Man its nice seeing all that new color sprayed.
I'm hoping to do exactly what your doing. Everything I touch I want new paint on it because there is nothing worse than putting old stuff back on that looks like its old. HighJack time As for the bed bolts. I sprayed everything with PB blaster and let it soak for a day or so. Hit it again and followed it up with a little torch so the liquid would heat up and soak into the metal. Right before I attempted to loosen a bolt I would spray some more. Turn the bolt some and then spray. A trick I learned long time ago is when your trying to loosen a bolt is loosen it a little and tighten it back up just a hair. Loosen a little more and tighten Shoot some of that PB blaster on the thread and it should work its way loose. The long bed bolts and wood supports well they where a pain and felt the fury of my cut off wheel. All the bed sides, tail gate and front tin I was lucky for them to come loose with that PB blaster and a torch because I did not want a bolt snapping in those welded nut zerks. |
02-25-2009, 07:08 PM | #78 |
1 thing at a time is progress.
Re: My 65 Build
Looks like your making some great progress. Keep it up.
Alan
Philippians 2:14-16 |
02-27-2009, 04:50 AM | #79 |
Re: My 65 Build
Old Skool is back on all four wheels, brakes bled, steering mostly complete. Stay tuned for updated progress pics.
02-27-2009, 11:25 AM | #80 |
Re: My 65 Build
You better before Joe hits you up with his famous where are the pictures image.
Congrats on getting it all rolling again. |
08-15-2009, 08:55 PM | #81 |
Re: My 65 Build
Well I am alive, and kicking. Took a detour on projects, and haven't been on this site for a while. Summer time came near, and it was time to get the lake rod ready. I have made some progress on the truck. Will re size some pics, and update in the next couple of days. ... It runs, and runs well.
10-12-2011, 12:14 PM | #82 |
Re: My 65 Build
Hi...Id like to use your idea,just wondering where you located and cut the hole in the firewall for the harness to meet up with the conduit ?
Thanks, Ed |
10-12-2011, 12:15 PM | #83 |
Re: My 65 Build
Hi...Id like to use your idea,just wondering where you located and cut the hole in the firewall for the harness to meet up with the under fender conduit ?
Thanks, Ed |
03-30-2017, 02:32 AM | #84 |
Re: My 65 Build
Long time no post! Even forgot my login and password. That truck hasn't made much progress, however, I have a new build (not g pa's truck) that I am acquiring parts for. Soon will start a new build thread. It is a 66 short bed, full air ride, custom rear frame clip, lots of fun to come. Life got in my way for a while! A long while! This new build I will keep up on. Have almost all the parts and pieces already. Hope you guys will like it. I will title the new one AFC 66 Short Bed. Cheers!
02-23-2018, 02:07 AM | #85 | |
Re: My 65 Build
02-23-2018, 02:11 AM | #86 |
Re: My 65 Build
I welded in the conduit, and then eyeball engineered the 2" diameter hole to match, I know I am a few - 7 years late. sorry, just got back into this website.
