Old 02-23-2018, 12:35 AM   #1
duramax55
55 2 hood question
I am alingning my hood on my 55 gen 2 and when i close it the pasanger side hinge stays up at the fire wall when i close the hood. then have to push that side down. I know that that is a problem with those hinges but wnat has to be done to fix that??? Thanks Denis
duramax55 is offline   Reply With Quote
Old 02-23-2018, 07:52 AM   #2
bowt1ed
Re: 55 2 hood question
duramax55 - Assuming your springs are still strong, you need to shim the upper hinge mount (only) at the firewall. This will rotate the axis of spring tension. You will need to shim both sides. I recommend starting with 1/8" shim and go from there. I had the same issue and worked like a charm.
Cheers, Jim
bowt1ed is offline   Reply With Quote
