Can anyone confirm is this a 72 cab for cable throttle
Wondering if anyone can confirm if this is a 72 cab I have a bit of a Frankenstein here trying to figure out what I have and how to plan the build.
Here’s pics of the pedal area, rear view mirror mount and cargo lamp. I believe these are the areas with the most difference year to year. |
Re: Can anyone confirm is this a 72 cab for cable throttle
Doesn't look like it. There shouldn't be a hole behind where the throttle mounts on a cable throttle truck. Does it have two studs on the floor at the base of the gas pedal, or the nutplates under the floor for them?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Do you still have the VIN on the driver's door jamb? That will tell you for sure. I can't see it very well in the pic, but it looks like the the roof has holes to mount the rear view mirror. If so, it's not a 72. They attach directly to the windshield on 72s. Your drivers door is not a 72 either.
72 C10 lwb fleetside -stock 350/350 combo |
I just went through this with my truck. I'm with 68 pos. I would say its a 71 if it has the vent in the drivers side door jamb by the vin.(only 71-72?) Could it be possible the PO drilled holes in the roof to relocate the mirror?? Is the windshield you pulled off it original and has the mirror on it?
It has studs on the floor for the pedal, it does have holes for the rear view on the roof. It doesn’t have a vin on the cab, that would be too easy. Agree doors for sure are not 72, it is a factory A/C cab. So maybe a 71???
The vin and title is 1967 but cab obviously isn’t a 1967 cargo light means 70-72 right? Last edited by Problems; 02-23-2018 at 12:15 PM. Reason: Spelling |
#6 | |
![]() Join Date: Jul 2001
This, VERY easy to spot the '71 only cab roof. As mentioned, a stamped raised pad in the roof line for the mirror mounting. Only cab in the 67-72 line up that has such.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#8 | |
That's good to know. I'll have to take a closer look at my cab to see if the holes were filled. I don't have a raised spot there or holes but my mirror is on the windshield.
That sounds like a '72
![]() Join Date: May 2003
Does it have the vent in the B pillar by the vin tag ? If it does , and there's no raise area for the mirror then it's a 72 !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 02-23-2018 at 12:33 PM. |
I say generally 71's have the raised spot for the mirror because I have a buddy with an all original, paint and all early production '71 that doesn't have it, or the vent in the door jamb. I have also seen at least one '72 that had the raised spot but never had a mirror screwed to it. I assume it was an early production truck too.
No vent in the door jam so I guess I’m going with it’s a 1970. Not that it matters much for what I’m doing but it’s just nice to know.
Thanks for all the quick help!!! |
#15 |
![]() Join Date: Sep 2007
a 72 has the rearview mounted to the glass doesn't it? quickest way to verify a 67 cab is the dash as some 67s have a panoramic back window
1967custom |
#16 |
My 72 cab was date stamped on the engine side of the firewall. Don't recall exactly where it was but I do remember that it was not coded, but actually had an abbreviated month and year. I'll look tonight and see if it is still visible through the paint that it now has.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#17 |
OK, I can eat crow with the best of them, or at least a little bit...I found the stamping on my 72 cab. It is behind the front right tire on the toe board, but it is coded, kinda...
15_2_1972 You would likely have to remove the inner fender to really see it. I don't know if they did this for all years or even in the same place, but if you find yourself without the front right inner fender it wouldn't hurt to look.
