04-28-2004, 01:52 PM | #1 |
one set closer
rear end
is there any different beteween the 67 rearend and the 87 and older rearend. and if so exaclty where i'am on worry about where you bolt the bracket for disc brake (ONLY THE BOLT PATTERN). i am going to try something that will save me alot money thanks
04-28-2004, 02:15 PM | #2 |
I'm confused on what you're asking. The diff between a 1967 rear-end and newer rear ends, or older?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
04-28-2004, 02:21 PM | #3 |
Bucket of Bolts
The '67 rear ends will be Eatons or Danas, whereas the '87 rear ends will be GM Corporate axles. I don't think disc brake parts interchange, but I am probably wrong. You might be able to get the 14 bolt disc brackets to go on the Eaton HO52.
This is the project that never ends, yes it goes on and on my friend.... |
04-28-2004, 02:44 PM | #4 |
one set closer
i'm not going to use any of the part from the 87. i just need to know if the bolt pattern is the same. thanks
04-28-2004, 08:44 PM | #5 |
Fabricate till you "puke"
is that a 1/2, or 3/4 ton truck?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-28-2004, 11:28 PM | #6 |
its all about the +6 inches
If you are dealing with a 1/2 ton, then the bolt pattern isn't the same...6 lug '67 verses 5 lug from 71 up to 87.
3/4 ton truck...same, although the holes for the wheel lugs are a tad bigger on the 71 and up. |
