02-22-2018, 01:42 PM | #1 |
Steel Fuel Line from Pump to Carb (SBC 350)
I rebuilt my Edelbrock 1403 carb and am going to be putting it back on my Small Block 350 4-bolt main from a 1975 C20 soon. The fuel pump is stock, as is the manifold, but I have an adapter between the carb and the manifold. I am using a hardline 90 degree adapter on the carb with a fuel filter on the end.
My question is: are there any fuel lines that are pre-bent that might work with that setup? If the top section that goes back towards the carb is long enough, I would be OK with cutting and flaring the end to connect it directly to the fuel filter / hard line on the carb. Otherwise, is it likely that I will have to bend the fuel line myself, and if so is it really that difficult? I have a pipe bender and flare tool from harbor freight, if that helps. |
02-22-2018, 04:58 PM | #2 |
Re: Steel Fuel Line from Pump to Carb (SBC 350)
I have a similar situation, 1405, Eddy manifold + 1" spacer, and would like to get rid of the short rubber hose from the cut off OEM metal line to the carb.
There are hard lines that include a filter housing that end about where the OEM line takes the bend to the Qjet. Haven't found a pre-made metal line to run from the pump to that end. Found a few flex line options. But that just flip-flops the metal/rubber parts. |
02-23-2018, 08:54 AM | #3 |
I would buy a couple pieces of hard line. Take a coat hanger and bend that for a template. And try your hand at bending your lines. I bent all my fuel and brake lines on my build, not that hard once you get a handle on it.
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
02-23-2018, 11:42 AM | #4 |
Robert Olson Transport
for about $20 there is a tubing bender that can be bought at most auto parts stores works like a charm
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
02-23-2018, 02:25 PM | #5 |
This is the tubing bender that I have:
https://www.harborfreight.com/tubing-bender-3755.html This is the flare tool: https://www.harborfreight.com/7-piec...-kit-5969.html Is it necessary to do a double flare on the fuel line? CAn anyone link me to which nut I need to slide onto the fuel line before doing the flare? I believe the connection is an AN6 connection? |
02-23-2018, 05:25 PM | #6 |
Those will work just fine.
02-23-2018, 06:36 PM | #7 |
You will use 3/8 hard line, and 5/8-18 tube nuts. I would recommend that you also install a fuel pressure regulator, as edelbrock carbs can be pretty sensitive to fuel pressure.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
02-23-2018, 10:05 PM | #8 |
I made my own out of aluminum tubing. I also used a bender that I got at ace hardware, its a giant spring made for bending copper line. lets you bend it tight and not kink it. been working great for 2 years.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
