Old 02-25-2018, 10:01 AM   #1
cgster
Replacing door seal weatherstripping
When I had my rocker panels replaced, the guy that did the work didn't leave and edge for the weatherstripping to fit around so there is nothing to hold the weatherstripping in place in the rocker panel area. Will the sill plates be enough to hold the rubber in place?
cgster is offline   Reply With Quote
Old 02-25-2018, 10:11 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Replacing door seal weatherstripping
No . you need that edge to install the seals
Old 02-25-2018, 10:39 AM   #3
Lanman1972
Lanman1972's Avatar
Post a pic, the edge for the door seal is part of the outer rocker. Not sure why someone would remove the edge.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
