Old 02-27-2018, 03:56 PM   #1
6768chevylover
6768chevylover's Avatar
axle shim,3" lift?
Is it necessary to axle shim with a 3 inch lift?
6768chevylover is offline   Reply With Quote
Old 02-27-2018, 05:41 PM   #2
Spf79
Spf79's Avatar
Re: axle shim,3" lift?
I think you can get away without one... Although it would not hurt to get one.
Personally I would shim it if you have it apart. Make sure to run metal shims, I think mine were $45 and change to my doorstep. I can't remember what degree of shim I used for a 5" overall lift, so you may have to do a little bit of researching to figure that one out.
Good luck!
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 02-27-2018, 07:34 PM   #3
hemi43
hemi43's Avatar
My 2" lift needed 3 degrees.
hemi43 is offline   Reply With Quote
