Old 02-28-2018, 03:40 PM   #26
padresag
Re: 53 years young
old gas in the tank can give you a problem unless you have cleaned it out
ron
padresag is offline   Reply With Quote
Old 02-28-2018, 09:22 PM   #27
harpo231
harpo231's Avatar
Re: 53 years young
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-04-2018, 10:32 PM   #28
'65fleetSide
'65fleetSide's Avatar
Re: 53 years young
Good news!! I was able to rebuild the Rochester Monojet carburetor and put it all back in and boom it lives... however when I go to apply and gas it immediately dies. Also the carb has starting to spit fuel out of the top. But while its running its getting a good idle and seems to be working but I cannot rev up in rpm.
The issues:
engine temp went over 210 - has water
carb is spitting gas every now and then
no throttle response and then dies
Still needs more cleaning but I was able to clean a good portion of the back gunk and now it shows its good old orange self.
'65fleetSide is offline   Reply With Quote
Old 03-04-2018, 11:10 PM   #29
geezer#99
geezer#99's Avatar
Re: 53 years young
Retarded timing will make it spit like that.
What’s your initial timing?
geezer#99 is online now   Reply With Quote
Old 03-05-2018, 03:43 PM   #30
'65fleetSide
Re: 53 years young
To be honest I only found TDC and forgot to even look at my timing. Im gonna get a timing light this weekend but most likely it is retarded as apposed to advanced. It does idle better since finding TDC but I will double check the timing and hopefully be able get to reverse and roll out.
Old 03-05-2018, 03:49 PM   #31
'65fleetSide
Re: 53 years young
For the engine oil should I just use a 30w conventional? or 10w-30 conventional?
Old 03-12-2018, 01:14 AM   #32
'65fleetSide
Talking Re: 53 years young
JUST AN UPDATE!!
So far I have replaced the:
stater solenoid
alternator
belt
spark plugs
oil/filter
spark plugs
plug wires
distributor
rebuilt carburetor
battery
All this and it finally runs, after 26 years sitting out in the elements she's purring. I have a slight timing issue but that will get takin care of shortly. Brakes on the other hand have been a bit of a nuisance but hopefully figured out this week. Im looking to bleed the lines and get some pressure back in them. If anyone knows of a good aftermarket conversion to discs that would be helpful. Thanks for the help and I look forward to sharing his first run down the road soon.
1965, c30, restoration
